chook Member 30 Member For: 14y 9m 21d Gender: Male Posted 25/04/11 09:20 AM Author Share Posted 25/04/11 09:20 AM (edited) im thinking they arent anygood full stop... even standard on repeated dyno runs they struggle Edited 26/04/11 12:55 AM by Dagabond Quote removed.... Link to comment Share on other sites More sharing options...
tonyv EPC Member Donating Members 1,598 Member For: 16y 2m 16d Gender: Male Posted 25/04/11 09:21 AM Share Posted 25/04/11 09:21 AM Stock zorst will make it heat up quicker Link to comment Share on other sites More sharing options...
vx8255 Member 36 Member For: 15y 20d Gender: Male Location: Melbourne Posted 25/04/11 10:24 AM Share Posted 25/04/11 10:24 AM (edited) yeah I took you advice and drove it in performance mode as well and I think mine might of just touched on the limiter as well but was thinking that would it be better to short shift 2nd to 3rd and to 4th ? I reckon the auto wants to rev it a little to hard and it would keep it in the meat of the torque? Also I reckon std cooler is probably hurting it at the end of the track..cant wait for the coooler to arrive and perhaps relocate that battery and see what happens..We tried short shifting at about 5500rpm to keep it more in the torque band and it went slower, especially in mph. After last times limiter issue, I even brought an autometer multi stage adjustable shift light tacho, to play around with shift points(manually), but found there to be no good tacho pulse to tap into, it's now on my mates VH . Performance mode(other than on the 1-2 shift) seems to produce the goods in mine, although I've never tried normal mode, that could be worth a look? If I can achieve 11.8-9@117-119mph with injectors, cooler and cat/cat pipe replacement, that will see me out for the distant future. Edited 25/04/11 10:34 AM by vx8255 Link to comment Share on other sites More sharing options...
shananp Member 248 Member For: 15y 6m 9d Gender: Male Location: Werribee Posted 25/04/11 10:40 AM Share Posted 25/04/11 10:40 AM Manual mode is the way to goJust have to be quick to change on the 1-2 shift other than that other gears are alot more easier to shift at the right time. Link to comment Share on other sites More sharing options...
vx8255 Member 36 Member For: 15y 20d Gender: Male Location: Melbourne Posted 25/04/11 10:51 AM Share Posted 25/04/11 10:51 AM (edited) I agree with your statement for anything with some power and torque(more than 350rwkw, 8000n of tractive effort), but on these lower powered examples, it seems to need it's neck ringed out just before the limiter to aid in recovery to the next gear, if I could of got my shift lite to work that would of been the ticket in manual mode, otherwise the consistency is just not there, I don't like guessing 200-300rpm off the factory tacho. But each to their own, you do whatever gives the results. I think the auto software could be a good thing, when it's finally finished and can be flashed stably.Also I reckon std cooler is probably hurting it at the end of the track..cant wait for the coooler to arrive and perhaps relocate that battery and see what happens..Are you getting aftermarket piping with you cooler? As I believe the stock piping is absolute junk. It leaks at the joins(even if repeatedly tightened), expands under boost and has even been known to burst under the right conditions. Edited 26/04/11 12:56 AM by Dagabond Quote removed.... Link to comment Share on other sites More sharing options...
chook Member 30 Member For: 14y 9m 21d Gender: Male Posted 25/04/11 11:54 AM Author Share Posted 25/04/11 11:54 AM We tried short shifting at about 5500rpm to keep it more in the torque band and it went slower, especially in mph. After last times limiter issue, I even brought an autometer multi stage adjustable shift light tacho, to play around with shift points(manually), but found there to be no good tacho pulse to tap into, it's now on my mates VH . Performance mode(other than on the 1-2 shift) seems to produce the goods in mine, although I've never tried normal mode, that could be worth a look? If I can achieve 11.8-9@117-119mph with injectors, cooler and cat/cat pipe replacement, that will see me out for the distant future.Yeah I was thinking the same thing about just leaving it in drive...hmmm maybe when I fit the cooler ill try it!I totally agree 11.9-11.8 would see me out as well! cant complain with that kinda times for a car that you drive to the track with.Are you getting aftermarket piping with you cooler? As I believe the stock piping is absolute junk. It leaks at the joins(even if repeatedly tightened), expands under boost and has even been known to burst under the right conditions.Yeah I will be getting piping! but I was watching the boost guage all the way down the quarter and it was holding 15psi all the way down beautifully Link to comment Share on other sites More sharing options...
FSIX Member 566 Member For: 19y 3m 26d Posted 27/04/11 02:02 AM Share Posted 27/04/11 02:02 AM Any of you coming to the Ford Nats @ HPR June 10th and 11th, cold Friday night good for a PB and plenty of runs. Link to comment Share on other sites More sharing options...
F1PERFORMANCE Donating Members 104 Member For: 15y 11m 6d Gender: Male Location: VIC Posted 27/04/11 06:49 AM Share Posted 27/04/11 06:49 AM Where do we enter Mark? Link to comment Share on other sites More sharing options...
vx8255 Member 36 Member For: 15y 20d Gender: Male Location: Melbourne Posted 27/04/11 07:03 AM Share Posted 27/04/11 07:03 AM Where do we enter Mark? orhttp://www.fordforums.com.au/showthread.php?t=11321780 Link to comment Share on other sites More sharing options...
