xrkiwi Member 22 Member For: 17y 7m 21d Posted 22/04/11 06:24 PM Share Posted 22/04/11 06:24 PM Was Driving my ute home 2 nights ago went through some road works and my warning lights and beepers went mad abs and dsc came on and fault 2! was not braking at the time.Pulled over checked everything brakes still worked no squeals no leaks drove into Ford,they were way to busy to do any thing (long weekend)Quickly take a look at lights and master cylinder(fluid levels not moving)and tell me a sensor has probably broken in the hub.Any one got any Ideas how likely this is or what the problem could be...Brake pads are all good and all wires look to be connected. Link to comment Share on other sites More sharing options...
_John_ Member 287 Member For: 14y 4m 6d Gender: Male Posted 22/04/11 09:09 PM Share Posted 22/04/11 09:09 PM I`d pull the wheels off and check there isn`t a dirty sensor, one could have crap on it. that won`t cost you anything other than a bit of your time. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m Gender: Male Location: @ my laptop Posted 22/04/11 10:50 PM Share Posted 22/04/11 10:50 PM have you been doing any burnouts? Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 10d Gender: Male Location: Christchurch, New Zealand Posted 23/04/11 12:45 AM Share Posted 23/04/11 12:45 AM the sensor and rotor are exposed in the BF and probably the same in the FG so if a stone got up there it could take the pickup tip off the sensor or as stated dirty sensor can cause issues. Link to comment Share on other sites More sharing options...
xrkiwi Member 22 Member For: 17y 7m 21d Posted 23/04/11 06:55 AM Author Share Posted 23/04/11 06:55 AM No burnouts unfortunately.Bit of dust on rear sensors do I need to take rotors off or just take sensors out and clean them. Link to comment Share on other sites More sharing options...
winstor Member 611 Member For: 15y 11m 30d Posted 24/04/11 12:13 PM Share Posted 24/04/11 12:13 PM I get the same problem every now and again, seems to be triggered by sharp bumps. Link to comment Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 28d Posted 25/04/11 05:00 AM Share Posted 25/04/11 05:00 AM So Ford didnt do a code test for you? Has the warnings come up again or did they go away after cycling key? Link to comment Share on other sites More sharing options...
xrkiwi Member 22 Member For: 17y 7m 21d Posted 25/04/11 08:19 AM Author Share Posted 25/04/11 08:19 AM found the problem it would appear that the gravel had worn through the outer wiring casing shorting 2 wires.Ford were unable to run diagnostics because they were flat out (long weekend )but it was booked to go in tommorrow.Problem solved Thanks All Link to comment Share on other sites More sharing options...
aussie1926 Donating Members 176 Member For: 15y 6d Gender: Male Location: Muswellbrook NSW Posted 27/05/11 04:52 AM Share Posted 27/05/11 04:52 AM I had the same problem on my fg ute but it was a faulty switch on the brake pedal Link to comment Share on other sites More sharing options...
Timmy-XR6T Silver Donating Members 179 Member For: 15y 6m 15d Gender: Male Location: Sydney, Inner South Posted 15/02/13 09:56 PM Share Posted 15/02/13 09:56 PM im having the same problem. additionally it takes my brake lights 1 - 5 seconds to turn on which makes driving in traffic interesting. going down this morning to check out brake switch and will pull the wheels off as well to take a look. its annoying the crap out of me. Link to comment Share on other sites More sharing options...
