  • Member For: 18y 11d
stock ZF 6 spd
Few mods to the actual car, touchscreen in the ICC, carputer in the left side footwell (hooked directly to the battery with a new set of wires) with ignition sense wire on the hand free phone loom under the fuse panel.
then just some power mods; Zorst, IC, CIA, Injectors, Tune
when it stopped working, all I had done was replace a move a fuse which I had in the wrong spot (7.5A fuse for side mirrors etc) was on the wrong side in a not used slot so I moved it to the correct location, and also pulled the car puter out to do some updates didnt really touch anything thou... ive pulled out all the looms in the passenger footwell and reseated them all still no help :(
So im guessing it's either the trans computer or the PCM that is dead... but I cant belive there is no error code comming up! and if you unplug the loom going into the transmission it is exactly the same... still no error codes and still nothing on the dash as youd expect so im more leaning towards dead transmission computer
  • 4 weeks later...
If anyone was wondering... when I found that my mirror fuse was in the wrong spot I got my owners manual out and found another use in the "wrong" spot.. had totally forgotten about it and yeah anyway it was the 10A "rapier" fuse which goes to pin 9 on the tranny loom which is the IGN sense line... pissed at my self for not remembering moving it, more pissed at the ford manual which doesn't match the car. Glad I never ended up taking it to ford!
  • 3 weeks later...
  • Member For: 17y 3m 22d
I have similar problem I went to work this morning and my car went into limp mode and so I hooked up the flash tuner and no codes detected so kept driving about 500m down the road car shut down wont start nothing and then the icc said security code error the flash tuner saying its not matched with this vehcile any idea what this could be?
