Fg Xr6T Rear Wider Than 275's?
fehlbie
  • Member For: 22y 1m 28d
I've got 285's on the back of mine (G6ET) with King SSL's and no other suspension mods with no problems at all (even with 5 in the car....)
  • Member For: 14y 9m 21d
I have a 9 inch rim with a 35 off set and 285's
10inch rim will fit no dramas and I reckon a 295 is possible with a slight pump perhaps 305!
I am sure I have heard of guys getting 295's under with no probs
  • Member For: 15y 7m 29d
yEH I RUN 20 X 10 +35 offset rims with 285's on the rear with no probs at all even with 4 full grown blokes on board.
I am going for 295's next and then once I get the guards looked at (there is a tiny lip that I think will take a pannel beater to remove properly) I'll go even bigger.
With the weight and power of these things you need all the rubber on the road you can get IMHO
  • Dropping a turd
  • Member For: 17y 3m 24d
whats the fattest rubber you can comfortably fit on a 9" rim?
probably a 265 if its an 18 or 19. Anything wider and the tyre wont sit right.
Edited by arronm
  • You've changed man....
  • Member For: 14y 1m 23d
thanks mate... they are 20"s... does that make a difference? clearance is non issue as I have a tray back ute.
  • Dropping a turd
what model falcon you putting them on , if its FG you probably want a 10 on the rear. 265/30/20 will go nice on a 9 inch rim
