  • Member For: 13y 11m 27d
hey. just wondering if anyone knows if the FPV or ford dealers can tell if a car has been tuned or not using a capa flash tuner even if ya flash it back to standard tune before you take it in for a warrenty claim if needed to do so??
cheers
https://www.fordxr6turbo.com/forum/topic/74359-tuning-2010-fg-f6/
  • Resident idiot.
  • Member For: 14y 6m 23d
Don't bother flashing it back. If your trying to claim warranty work at least be honest. They built the car for 310kw if you push out that at the wheels something might break. Why should they fix it?
If your going in because your air con is sh*t it won't matter how modded it is as it doesn't affect air con.
  • 777
  • Member For: 16y 2m 12d
They will know either way.
Mind you I have never had an issue with my dealer. My dealer has never given me grief about my tuning
  • Member For: 14y 8m 4d
Must be nice to have a dealer l ike that!
I had some mods done and I'm having some problems with my BOV and they said because I have flashed it, they won't cover it under warranty! even if its just a crappy BOV from ford, I have to get an aftermarket one!
wish my dealer was like yours :crybaby:
Edited by RHR
No need to quote above post. USE FAST REPLY
  • Waiting for the 1st N/A 12!
  • Member For: 17y 2m 2d
Each time the PCM is flashed it creates a log 1,2,3,4...etc. and if these flashes don’t match up with a ford genuine flashes and it’s certain proof an aftermarket flash tune.
Also as soon as there is any engine issue with the 4.0ltr T motor it’s almost an unwritten rule that ford Melbourne request the PCM to be taken out and sent down to them for further diagnostic. Ford Melbourne (engineers) has 10 times more visibility within the PCM then your local Ford dealer has.
Same goes for the ZF box if there’s a drama with it a ZF tech can tap into the ZF’s magnatronic (the ZF’s computer) and download and read applied torque I.e. did it at any time see 900 nm of torque come through it!
One thing to be very close with your Ford dealer locally but once you break something expensive and your have modifodied it and Melbourne get's involved then it's curtains I'm affraid.
  • Member For: 14y 11m 14d
you guys are trippers!!!
mine had an auto issue and it took me 4 visits to ford and twice the zf man from ford came to check it as well! each time I flashed it back to standard the day before taking it in and I got a new auto and diff bushes.
