Ebay Rotors
LazyBrennan
  • Replies 56
  • Member For: 13y 9m 21d
Cool aaron. I know its nothing but I think its best I ask... Those rotors in the link say 321mm. I cant imagine them being any different for the sake of 1mm, but then again the fpv brakes are only 3mm bigger. Does it really make a difference?
  • Member For: 16y 1m 21d
hey lazy,
If you don't mind me asking, how do you know the rears are smaller? have you actually measured them?
The reason I ask is because the rear rotor looks smaller because it has a smaller brake surface but when you actually measure them they are larger in diameter.
Its like some sort of optical illusion.
Being bf2 id say you have front 322mm rear 328mm but make sure you measure them with a ruler to be sure.
Hi paulie,
Now that you say that... I only say there smaller cause they look smaller.
Im not doing the rears for about another month after doing the fronts. So I will take the wheels off this weekend and have a look.
Thanks for that mate, Had no idea they are bigger but look smaller.
clearly I meant tape measure... 30cm ruler will be useless :roflmbo:
The easiest way to check is to see if the rear rotor is solid or vented. If vented then you definitely have 322mm/328mm
cheers.
Yes, vented should have little hollow partitions strait down the middle. Just google vented rotors and check out the pics. But I think you know the difference anyway.
  • Member For: 15y 9m 30d
Hey sorry to hijack but I found these ones on eBay. I got a horrible shudder so I'm just gonna replace the front rotors n pads. What u think?
http://www.ebay.com.au/itm/Ford-Territory-BF-XR6t-XR8-Front-Pair-Rotors-UP-Grooved-/150604561719?pt=AU_Car_Parts_Accessories&hash=item2310bb3d37
