  • Member For: 17y 10m 23d
My mods are:
Process West - Stage 1 intercooler
Process West – Under battery Pipe
Plazmaman Stage 1 Cold side Piping,
3” K&N pod Filter
Custom Airbox
Centre Muffler removed
High Flow Metal Cat 200 cell
Siemens 60lb injectors,
High Flow 180F Thermostat,
Iridium Plugs 0.8 gap
Walbro Fuel Pump,
Put in a generic Pitlane tune 2 years ago got 291RWKW. Was checked by tuner up here and given the all clear. Has run brilliantly since then.
Powercruise is coming up and I wanted more power. I've taken it to a Darwin Tuner (the guy who won the offstreet drags last power cruise in his XR6T) they seem to get advice and assistance from Herrod.
They had my car for a few days trying to improve the figures but unfortunately we only got 292RWKW. Attached is the Dyno readouts
post-12481-0-18017200-1302914710_thumb.j
post-12481-0-26382000-1302914759_thumb.j
Power seems to come on a bit quicker now and the Torque is crazy
We've had a chat and he has called some interstate tuners (Herrod I think). He has tried put more boost in but it just spikes and falls back to the same amount. We think it is the exhaust. Now I have removed the centre muffler. The cat I put in was a Magna Flow 200. Now I have a BF so I think the dump pipe should be good for 300KW.
I'm thinking of punching the cat to see what happens and how we then go on the Dyno. My concern is that I read somewhere here that I will then have uncontrollable boost after punching a cat unless I change the actuator and do the port flapper mod. I'm not real keen to do that.
I'm keen for any feedback particularly from the tuners as to what I should do or what could be stopping me breaking through the 300KW mark. I'm going to throw a PW hotside setup on before the next Dyno attempt but I don't think that will help the HP.
We don't have many tuners up here and the ones we do have don't get many XR6T's to play with. I'm very happy with the communication and the effort put in by my current tuner, This is not a bitch about the results. It just a request for some ideas on what is holding me back.
https://www.fordxr6turbo.com/forum/topic/74330-stuck-on-292rwkw/
  • Replies 71
Posted Images
  • A much better forum
  • Member For: 16y 10m 23d
You need a stronger actuator dude... Spring can't hold the wastegate closed once boost gets to 11psi... In top end...
You'll get 300 once you can hold boost up to 13/14psi...
  • Member For: 16y 8m 16d
Just as a guide, my mods are less extensive than yours and mine hit 300rwkw but eased off due to valve float (valve springs). Perhaps the actuator holding the higher boost helped. I dont have any other turbo mods, just actuator, maybe get one as they are quite cheap too.
Hope this helps a bit.
  • Member For: 19y 19d
the cat will help, but without the actuator, the boost will be falling above maybe 4500 rpm. the drama you may end up having is if you fit a stronger actuator and then the exhaust and cooler flow well, you may end up with overboost at 4000 rpm or so and you will need to port the turbo.
Ok ill get the actuator but keep the exhaust as is and see what happens. Who sells them online so I can get it posted here. I assume they come with an arm
  On 16/04/2011 at 4:24 AM, ratter said:
worm is correct.
See Mick! I am a good student! LOL I do listen to everything you tell me... :innocent::beerchug:
