  • Member For: 19y 3m 6d
Mate, 27mm front bar is good, 30mm is better. Rear bar works good too. I'd recommend you go adjustable on both. Beware the stock front links though. Mine kept breaking until I converted to the heavy duty Whiteline bardies that you can cut to length. No dramas since using these bad boys.
https://www.fordxr6turbo.com/forum/topic/74323-sway-bars/#findComment-1097172
  • Member For: 16y 10m 18d
If you have a little lightweight 6 cylinder motor in the front then the 30mm bar may not be the best option, stick with the 27mm. Definately replace the rear bar with the 23mm.
If you are fortunate enough to have a real motor up front, a V8, then the 30mm is a must have.
And I have never understood the need to have an adjustable bar? Seems to me to be added cost for no real purpose - but that's just my opinion.
Never had a problem with links? If one bent or broke one I'd just grab another one from the wreckers for ten bucks.
Edited by xr6greg
https://www.fordxr6turbo.com/forum/topic/74323-sway-bars/#findComment-1097213
Yes.
Manufacturers, Ford/Holden/etc, develop a suspension package that the general community is comfortable with.
The 30mm is standard on the FG, and about the same tortional ability that the standard BA BF front bar had, but the improvement on fitting a Whiteline 33mm bar to an FG is significant.
https://www.fordxr6turbo.com/forum/topic/74323-sway-bars/#findComment-1097218
  • Member For: 18y 6m 9d
I have a 27mm front and stock rear. My car handles great at the track.
Don't fall into the trap of making all your suspension rock hard, you'll end up backwards, literally. You want the rear end to have a little give to transfer the weight around more, easier to get the power down.
https://www.fordxr6turbo.com/forum/topic/74323-sway-bars/#findComment-1097299
