Spare Tyre
PSI40T
  • Member For: 16y 5m 27d
ok so I have a fg xr6t with aftermarket 6 piston brembos at the front, obviously needed to get wheels that would clear them so got myself some 20's...
Now I was thinking what if I need to replace the front rim due to a flat tyre??? Would the spare tyre clear the brembo brakes?
Are you front wheels and rear 20" wheels the same width and offset?
This idea may work, but you'd want to practice at home.
Obviously, the spare will fit over the rear brakes.
Rear flat, no prob.
Front flat?
Step 1. Still put spare on rear.
Step 2. Swap flat front with rear wheel just removed.
Requires jacking car twice (and same side if directional tyres) but may work if the rare event of a flat.
  • A much better forum
Carry a spare standard caliper and disc around for each side in the boot. Take off wheel and brake. Replace both :stirthepot:
  • 777
  • Member For: 15y 10m 21d
Id day mate you would have to put the spare on the rear. If you get a flat in the front pull off a full size off the rear and pop it on the front.
A hassle it would seem but the only way without having to purchase a 20" spare
  • 2 weeks later...
  • Enforcer
  • Member For: 16y 2m 13d
dont put the spare on the rear you will get axel bind and stuff the diff when you turn a corner..its not good for it anyway.
An aftermarket FPV copy for $199 is the go with +35 offset... I drove around for a year before I realised that my factory 18inch steely didn't get over my 8 pot fronts....
  • Member For: 16y 5m 6d
BA XR8 18" rims clear Brembo calipers. That's what I'll be running on my taxi. For a spare wheel, call wreckers and specialist wheel/repair places and you'll end up with a wheel for around $100. Just make sure that you get it checked for buckles before putting it in the car though.
