Click Noise From Clutch Fg Falcon
sam_rigger
  • 6 months later...
  • Member For: 15y 8m 2d
I have a click in my FG XR6-T clutch pedal. It's not the switches mentioned above, but in the spring on the top left hand side of the cluttch lever beside the pivot. It clicks just before the pedal returns to the stop - the small spring comes back over centre and clicks the plastic mount. It can be felt it as it moves if you are a contortionist. It goes away if sprayed liberally with silicon oil, but does come back.
Just poor design.
Pain in the a## to fix, small problem and tedious job with no access.
  • Member For: 18y 9m 8d
I have never heard the reverse lockout solenoid click from inside the car. I have had no console, in my car and still not heard it. I would think it is something else other than the solenoid. The solenoid engages over 7km/h, so has nothing to do with the clutch pedal etc...
  • 2 months later...
  • Member For: 17y 10m 6d
Yer mine does it, but the only time I usally hear it is when im in maccas drive through
YES! First time I noticed it too lol.
Also sometimes my Cruise control won't work for a while, could this be the clutch sticking thing j.d was talking about?
  • Member For: 14y 1m 27d
Just poor design.
^^ this is spot on, mine does it too.. If you get down there and have a look, its the spring and poor design. I tried silicon spray too with the same effect. After a while you get used to it anyways. Might need to experiment with a longer lasting grease or even graphite.
