boust Member 6 Member For: 14y 10m 9d Posted 05/04/11 09:08 AM Share Posted 05/04/11 09:08 AM hi there,,,a question no one seems to be able to answer.Do 6 piston front // 4 piston rear BREMBOS fit under the standard GS wheels ????The performance shops I have rang can't seem do not have a concrete answer either way.I have also rang a couple of fpv dealerships but no definite answer there either . So thought someone out there may have done this conversion , or put a GS wheel over a GT 6 pot / 4 pot combothanks for any feedback in advanceBoust Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 22d Gender: Male Posted 05/04/11 09:32 AM Share Posted 05/04/11 09:32 AM well they have fpv wheels, so I can't see why not. there like dark argents in just in silver so I would say yes. Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 3m 21d Gender: Male Location: Victoria Posted 05/04/11 10:07 AM Share Posted 05/04/11 10:07 AM Need to check offset... Front will be fine... Rear Needs to be the wider offset (+28)...Usually they only fit wider ones on cars fitted with 4 pot rears from factory. Easy way to tell. Pull one off and see if it says "rear only" on the inside... Link to comment Share on other sites More sharing options...
boust Member 6 Member For: 14y 10m 9d Posted 05/04/11 10:49 AM Author Share Posted 05/04/11 10:49 AM Are you sure, don't want to spend $4500 and find out they don't fit. Link to comment Share on other sites More sharing options...
xpl0sive Member 421 Member For: 15y 9m 23d Gender: Male Location: Melbourne Posted 05/04/11 11:27 AM Share Posted 05/04/11 11:27 AM (edited) The rears are the same offset as the front...I have the same wheels, also off a GS. I also have a set of 6 pot Brembos waiting to go on, don't have any rears though but planning to buy some. Someone correct me if I'm wrong, but I believe it was only the BA 18 inch FPV wheels that had the staggered offset. FYI, the same wheels are also available on the BF GT-P which has the 6/4 combo. Edited 05/04/11 11:31 AM by xpl0sive Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 3m 21d Gender: Male Location: Victoria Posted 05/04/11 11:39 AM Share Posted 05/04/11 11:39 AM Pretty sure they are staggered on 4/6 combos all the way through... Link to comment Share on other sites More sharing options...
xpl0sive Member 421 Member For: 15y 9m 23d Gender: Male Location: Melbourne Posted 06/04/11 12:18 AM Share Posted 06/04/11 12:18 AM (edited) ok, did a bit of research on this as I wanted to confirm for myself also. What I have found is this:- FPV sedans have the same offset front and rear from BF MK2 onwards only, so anything prior have the different offset rears.- FPV utes have always had the same offset for both front and rear.- The 8mm wider offset for the rears on the earlier FPV sedans was only for increased track to improve handling. It wasn't for brake clearanceSo in short, the GS wheels should clear the Brembo rears. After all, plenty of F6 and GT owners have upgraded to the 4 pot rears on the back.If any of this info is incorrect, someone please correct me.boust, if you want to be 110% sure, see if you can meet up with someone running 4 pot rears, and test fit your rims on their car. Edited 06/04/11 12:19 AM by xpl0sive Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 17d Gender: Male Location: Perth Posted 06/04/11 01:07 AM Share Posted 06/04/11 01:07 AM Need to check offset... Front will be fine... Rear Needs to be the wider offset (+28)...Usually they only fit wider ones on cars fitted with 4 pot rears from factory. Easy way to tell. Pull one off and see if it says "rear only" on the inside...Not true. I have R Spec rims on my F6 with +36 on the rear and 4 piston brembo and there is plenty of clearance. Link to comment Share on other sites More sharing options...
arm79 Donating Members 214 Member For: 15y 8m 18d Gender: Male Location: Melbourne Posted 06/04/11 02:24 AM Share Posted 06/04/11 02:24 AM (edited) I have R Spec rims on my F6 with +36 on the rear and 4 piston brembo and there is plenty of clearance.Can confirm the same with my +36 Force rims (which are Dark Argents in another name/colour)... Plenty of room. Edited 06/04/11 02:25 AM by arm79 Link to comment Share on other sites More sharing options...
boust Member 6 Member For: 14y 10m 9d Posted 06/04/11 04:37 AM Author Share Posted 06/04/11 04:37 AM Yes you're right the only real way to tell is for someone to put one of these wheels on a GT or GTP. If there is anybody out there with this option available it would be so kind!!!!!! As this will be one of the best brake upgrade options for FG GS owners of the future. Link to comment Share on other sites More sharing options...
