Somewhere Around 400 - 500 (Hopefully The 500!)
  • Member For: 19y 4m 14d
Yeah injectors in and done a while ago.Just playing with a couple mild tunes at the moment with HP Tuners. Only get limited time to play with the car + no dyno + road testing = slow progress. Cheers.
  • Replies 69
Posted Images
  • Member For: 15y 8m 25d
Mate I have a 4 inch dump to a 2.5 inch exhaust needs to be 4 inch but I just havent done it yet .
Dont really care about the pump power 470rwkw @ 21psi is good enough for me
  • 1 month later...
How is it coming along mate?
What plenum r u going to be running?
Edited by tray_182005
  • 7 months later...
  • Member For: 13y 10m 7d
Why would you place the wastegate on the turbine and not on the pipes? 500rwkw is a lot of power l!!! What size is that wastegate?? Is that a T4 flange or a T6 flange I cant tell by the picture id say T4 why wouldn't you use a split pulse turbine?
  • Member For: 15y 12d
Bought turbo off mate and wastegate in that position for better boost control apparently! still haven't got it going to test different exhaust housings but I will be if im not happy! It's a t4 flange and wastegate is around 50 mm if I remember correctly!
Cool mate should hold boost well!! You should of had your manifold made to suit a spit pulse won't make a difference if you put a split pulse turbine housing on it now.. Will be good to see this thing go once its finished. Hopefully it doesn't blow up like last time.
Edited by stee3
