Just Blew My Engine :(
riptide
  • Member For: 17y 2m 26d
You should see Tocchi's BA block in his drag Capri :) It's like 450rwkw or so. How long it lasts...no one can say!
  • Member For: 14y 1m 1d
I'm getting a bit of a miss on boost so taking it fairly easy until I sort it. I think that may have been what killed my last engine because it did the same thing. I'm wondering if it's a fuel pump issue (intank walbro) getting some air bubbles in the line or losing pressure or maybe a couple of injectors playing up. It seemed to be more noticeable in the morning when it was cooler on the old motor.
When I stripped the dead engine to have a look I noticed #1 and #5, which broke the rods, looked lighter in colour around the valve area under the head and #5 had aluminium spatter stuck to it.
Any help would be much appreciated
  • Member For: 16y 10m 6d
Wouldn't be coils would it??? I had alot of trouble with coils at first to ....but also had a couple of walbros die on me to ended upgrading to a freaken herrod one was like 600 .... Went to tuner yesterday to talk about next round of mods to go to around 450 said a forged engine was 8k ish but he was also wanting to do a cam upgrade...never heard ofthat before
Would coils cause detonation? and the lighter colour in the combustion chamber?
I would be cautious about doing cams too because I've read a lot of stuff in the forums here and don't recall coming across that either.
I would have thought a good intake, exhaust, intercooler, pump, injectors, valve springs and fuel supply with your built engine would be the go. A bigger turbo might also help and I read about dropping the compression ratio to allow increased boost. Not sure what level that might be required though.
Maybe do the cam on a NA motor but not a turbo?
I will happily be corrected if I'm wrong, I'm just repeating stuff I read :)
  • Member For: 15y 1m 1d
If your coils are failing then you wont get your spark under load properly. How old in km are the coils. As for the cams I also have read on the forum that no-one generally does the cams to get to 450kw. What has been stated above is a pretty good go.
  • 2 weeks later...
I have made a surge tank and will be installing it next week. Should be pretty easy now that the hard part is done. If that doesn't fix the engine miss I will have to test my coils and plugs and maybe test the injectors on my mates flow machine.
  • Moar Powar Babeh
  • Member For: 19y 4m 27d
+1, 1 litre is borderline. I personally wouldnt go any lower than 1.5ltr. 044's flow 305 litres and hour @ 3 bar. Do the maths on how long that takes too empty a 1 litre tanks (aprox 12 seconds) That doesnt leave a great safety margin if your intake pump was to fail.
Also, you have the return from the rail under the supply too the surge tank and return from the surge tank. This is going to give you a great deal of swirl in the tank, your also returning the hottest fuel closed to the pump inlet
I'd suggest instead of
Main Tank return
Main Tank supply
Fuel Rail return
run it-->
Fuel Rail return
Main Tank Return
Main Tanks supply
Attached is a pic of my tank before it went it. Top is fuel reg and return from reg followed by return too main tank and under that is supply from main tank.
post-7403-0-32244600-1305075417_thumb.jp
