riptide Member 733 Member For: 14y 29d Gender: Male Location: Auckland, New Zealand Posted 27/03/11 05:23 AM Share Posted 27/03/11 05:23 AM I was driving to work in the early morning and thought I would give the gas a squirt going up hill on a long straight. The boost had just started coming on and I had a full tank of gas. Something didn't seem quite right with the performance and there was a strange sound like a few quick, dull bangs and a flash of orange light, then just the sound of rolling wheels and then the engine light lit as I coasted to a halt :(Anyone got a spare engine or parts for a rebuild? Link to comment Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 16y 10m 3d Gender: Male Location: New Zealand, Palmerston North Posted 27/03/11 06:59 AM Share Posted 27/03/11 06:59 AM Oh that's sh*t bro.. had you done your air intake mod without getting a tune?? maybe some bad fuel??? Time for a forged engine??? if you go down that option lemme know how much it costs as I've been thinking about doing the same .. Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 6m 30d Gender: Male Location: Aspendale, Vic. Posted 27/03/11 09:30 AM Share Posted 27/03/11 09:30 AM quaddie is selling a motor . full motor for 900$ or so in the for sale section. Might be 100k old already but ye. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 23d Gender: Male Location: Probably above atmospheric pressure Posted 27/03/11 09:39 AM Share Posted 27/03/11 09:39 AM How did that happen!?!? Were you in a high gear letting the boost build or low gear? I know mine has hit 17 or so PSI on my flat 15PSI tune when letting it build in 5th uphill or on the freeway (bad move).You might need to hit up the wreckers if no one local has parts spare, good luck mate! Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 29d Gender: Male Location: Auckland, New Zealand Posted 28/03/11 06:26 AM Author Share Posted 28/03/11 06:26 AM (edited) Hi SteveHad it in perf mode going up a hill at about 100k's and gave it some gas and it just power surged then bogged, then went bangity bang flash and died. Guessing it was just too much boost or something. There are holes at the front of the sump on each side and a big one at the back above the cross member which blew straight down through the oil baffle plate and all. Have read a few sad stories now and would like to turn the clock back please.I'm hoping my head is ok and I might get a second hand block and fit it out with an "Atomic stage 1 kit" Seems like a waste of money going standard again. Anyone know the safe limits for a 2007 BF Mk2?Oh, yeah that looks a good deal *Beep*, I would take the lot, but NSW is a bit out of the way and your dollar is ^ Edited 30/03/11 09:54 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 16y 10m 3d Gender: Male Location: New Zealand, Palmerston North Posted 29/03/11 08:52 AM Share Posted 29/03/11 08:52 AM if your going to get a 2nd hand engine make sure you get one that's later than 06/06 that's when they upgraded the internals which should make it handle around 350rwkw pretty safe ... have you managed to find anything out about an atomic rebuild kit?? Link to comment Share on other sites More sharing options...
Wingnut Member 573 Member For: 16y 6m 12d Gender: Male Posted 29/03/11 09:53 AM Share Posted 29/03/11 09:53 AM He has stated it was an 07 BF so I would guess it already had the strong gear inside... It shouldnt have blown, I would be hitting up your tuner. I wouldnt be happy if mine went under those circumstances. But then again, loading these cars up like you did seems to end in tears quite a fair bit. I would suggest go for a stock bottom end as a replacement. It should be good for well over 400rwkw. What power did you have before it blew? Your sig names mods and tuner that's all.Good luck with the rebuild. Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 29d Gender: Male Location: Auckland, New Zealand Posted 30/03/11 07:15 AM Author Share Posted 30/03/11 07:15 AM (edited) Started stripping parts off the engine ready to remove from the car. Turbo looks good still.Looks like #1 and #5 have snapped the rods. #1 has put a hole through each side of the sump but #5 has cut the sump in half and part of the block. When I removed the turbo, parts of the block fell out and I thought it was the turbo falling apart.I have been given a BA non turbo engine.Does anyone know if it can be put straight in the BF and strap the turbo on?I thought there may be issues with compression (what boost can be safely run), the cams, no auto cooler mounts on the sumpand turbo oil return needs drilling. So if you know the answer to any of these things or can direct me to a thread I would appreciate it.I will post some pics when I get the motor out Edited 30/03/11 07:16 AM by riptide Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 2d Gender: Male Location: Sydney Posted 30/03/11 07:35 AM Share Posted 30/03/11 07:35 AM I would not be putting a NA BA motor in unless you want a timebomb under your bonnet. The NA and Turbo motors are very different and putting a turbo on the stock NA will blow it up.You would be much better buying a short typhoon motor from Ford for under NZ$4000 and know it will handle up to 400kw. If you stick with your origional plan, you will be replacing the motor again in the very near future. Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 29d Gender: Male Location: Auckland, New Zealand Posted 30/03/11 08:27 AM Author Share Posted 30/03/11 08:27 AM I appreciate the advice but I priced up a short typhoon from Ford and it's $5,175.I thought I might be able to build up a motor with decent rods etc over time ready for swapping out. My boss runs a race car with a na 3.8L v6 Expensive Daewoo with a flat 6psi boost and does real well so I was hoping to do similar.I just need to get it back on the road to tow the boat and get around You guys in Oz are lucky to have so many options. Most of the NZ performance shops specialize in Jap cars and Ford NZ tuck you hard Even the wreckers want about $4000nz for a long BA turbo. Link to comment Share on other sites More sharing options...
