Matthew Green Member 10 Member For: 17y 7m 14d Gender: Male Location: NSW Posted 19/03/11 02:09 AM Share Posted 19/03/11 02:09 AM Good Afternoon AllI have a stock BA XR6T that recently started misfiring badly. It could be a coincidence but I did clean some hoses and piping with water (wiping not spraying). I thought something could have been wet, but it’s been 2 weeks and the car has been hot so all moisture would be gone.The misfire is rather random, sometimes it won’t idle correctly, sometimes it’s under slight load e.g. a roundabout and sometimes only when full throttle.I took it to my local Ford dealer (Blacklocks - Albury-Wodonga) they advised it was a blocked fuel filter as fuel pressure was down. Replaced but the issue still exists. I thought maybe dirty fuel, it now has a fresh tank of 98.What should I try next? Coils? Plugs?If anyone knows of a good mechanic in the Albury-Wodonga area that would also be appreciated.Thanks in advanceGreenie Link to comment https://www.fordxr6turbo.com/forum/topic/73875-misfire-help/ Share on other sites More sharing options...
KutaXR6t Member 57 Member For: 16y 29d Gender: Male Location: Perth North Cost Posted 19/03/11 03:17 AM Share Posted 19/03/11 03:17 AM I had this issue with my 03 XR6T I changed the spark plugs and she was all fine. Get yourself some NGK iridium spark plugs for it, set me back about $100 at the time and fixed it up good as new! Link to comment https://www.fordxr6turbo.com/forum/topic/73875-misfire-help/#findComment-1090171 Share on other sites More sharing options...
Matthew Green Member 10 Member For: 17y 7m 14d Gender: Male Location: NSW Posted 27/04/11 12:14 PM Author Share Posted 27/04/11 12:14 PM An update on my issue. The car was at Ford for 2 days with no result. They replaced the fuel filter and then told me they couldn't replicate the issue, a quick drive out the freeway and sure enough under throttle it misfired and lost power. I decided I would give replacing the plugs and coils a go, I got a nasty surprise when I removed the coils. They where wet! I suspect this was from when I cleaned the engine, but I will check again soon to make sure the water didn't come from somewhere else.About 5 minutes of removing covers and Ford could have found the issue, useless.Anyway, all sorted and back to normal Link to comment https://www.fordxr6turbo.com/forum/topic/73875-misfire-help/#findComment-1100654 Share on other sites More sharing options...
