  • New Member
  • Member For: 20y 4m 6d
For the last couple of weeks I've been getting a fuel smell when the tank has been over about 3/4 full, yesterday I filled up and literally saw a stream of fuel leaking out from under the car. I assumed it was probably coming from the filler tube or something, but when I got home and checked it out it was coming from somewhere else right up the top of the tank. I assume from a breather or something?
It's a BFII sedan.
Just wondering if anyone else has had a similar problem? How much was it to fix? Did you need a new tank, ect.
Also I had a look in the service manual and it looks like you need to pull out the IRS cradle to pull the tank out. Is it possible to pull out without doing that?
https://www.fordxr6turbo.com/forum/topic/73868-massive-fuel-tank-leak/
  • 4 years later...
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 29d
Remove the rear seat base
The cradel/fuel module is housed there
Its screwed down on b series and ring locked on fg
If the car has had an aftermarket fuel pump installed the rubber o ring can and has been not seated correctly it will leak once the fuel tank is over that 3/4 mark full
Also lots of small rocks and debris gets up there and can sit under the o ring causing a less than perfect seal
  • Member For: 17y 5m 5d
I had the same problem as OP. Only pissed fuel out once at a servo, but I'd been smelling fuel for years if it was over half full and I threw it around. Lifted seat at the servo incident and all dry on top of the pump cover. Took it in to a mechanic and they found another plastic seam on top, where Ford install the fuel sender or whatever, was cracked. New fuel tank fixed it. I might have pics somewhere, I'll try to find them tonight.
PS big job, rear came out.
Edited by -Stever-
Yep, same as mine. Was dry in those spots, but pissed out from further along where you can't see. Ran down all over the rear from up on the very top.
Forgot to look for pics last night :P
But yeah, get a new fuel tank put in. Mine was from a wreckers. Fuel smell is gone 100% now, certainly no big spills.
  • Member For: 10y 1m 14d
yep , all fixed now , got another second hand tank as ford wanted $1400 for a new one , ill take pics of where mine was leaking from , it was a grommet/plug right at the top where the breather goes back into had split the adhesive around it
Found my pics, let's compare!
You can see the hole where the fuel pump drops in, down on the lower level (note don't try opening this with a full tank hahaha). Filler neck is the white pipe out the right side there.
The spot mine was leaking from
  • Member For: 16y 11m 7d
Not all b series are screwed down some BF2's have a FG tank from factory you should no that bud
I generalised as not all BF2's had it only late BF2's do
You should know that bud ;)
