Turbo To Manifold Pressure Drop
FAST-XR
  • EVIL T
  • Member For: 16y 1m 4d
I measured my hot side pressure on both tunes (from the actuator line at the turbo)
10 psi tune
Turbo Pressure: 11 psi steady
Manifold Pressure: 9psi and tapered to 7.5 psi
12 psi tune
Turbo Pressure: 14 psi steady
Manifold Pressure: 12psi and tapered to 9.5 psi
So iniatially I have a pressure drop of 2psi then somehow my manifold pressure drops another 2.5 psi while the turbocharger is still pumping out the same pressure...
Does this sound like a boost leak?????
a constant pressure should equal constant pressure drop right?
also is a 2psi drop overall acceptable? (that's inclusing hot side pipes, cooler, and cold side pipes)
Edited by FAST-XR
  • Replies 25
  • It's not a MKI!
  • Member For: 16y 6m 25d
Depends how far into the rev range it starts to taper off.
It may be part of the tune.
Constant pressure at constant revs is correct, but when you cahnge things like engine revs and turbo revs pressures will change.
  • EVIL T
What intercooler r you running. A 2psi pressure drop across a crap intercooler is not abnormal.
a HDI cooler, 580 x 220 x 100...
boost definately seems to start to fade when the motor is hot...
I pressure tested my intercooler piping on the weekend, and found no leaks!
so if my turbo is pushing constant pressure, and I have no leaks in my pipework, im thinking that I might have a leak in the intake manifold somewhere that gets worse after it gets hot...
  • EVIL T
It's acrross your core. With the HDI intercooler I had a 3-4 psi pressure drop @ about 19psi. We found this after changing over to a Plazmaman core and boost was up.
witht the HDI did your boost curve hold steady? or did it drop off at high revs?
  • 2 weeks later...
  • Member For: 13y 9m 16d
Also another thing to look out for is the blow off valve leaking under boost.
My R32gts-t used to do it bad just swapped it out and it was all good.
