  • 2 weeks later...
  • Member For: 19y 1m 12d
  On 09/03/2011 at 6:58 AM, brendoxr6t said:
previous mods include:
4"dump pipe, 3.5" cat, twin 2.5" pipes into twin 2.5" tips
injectors
valve springs
thr intercooler kit stage 2
wastegate upgrade
bigger fuel pump
new turbo housing and actuator
previously had a growler cai
and runs 14psi
yeah it is still stock internals
401 RWKW @ 14psi boost :roflmbo::roflmbo::roflmbo:
  • loitering with intent
  • Member For: 21y 9m 13d
inclined to agree :dontknow:
  • Toughest BA Turbo
  • Member For: 22y 5m 7d
IMO if a bigger turbo yes, but I doubt with just a bigger compressor cover.
Years ago some people on this forum (started with APS) would quote maximum boost as the boost applicable at the point at which maximum power was made, rather than the maximum boost used in the run. (this is buried in our archives somewhere). Some tuners apply maximum boost in the midrange, then taper it off before the point of maximum power.
They used the former definition, imo, to understate boost used.
So as there are 2 ways of interpreting maximum boost, I always like to see a graph. To me maximum boost is maximum boost.
Brian
  • Awesome...
  • Member For: 14y 10m 27d
When quoting KW, the boost at that RPM should be quoted. Not the maximum boost over the entire rev range.
Keep in mind he has an aftermarket plenum which flows a lot better than the stock, allowing more power @ less boost...
