  • Member For: 20y 20d
I have heard you can actually cause damage by opening the butterfly with your hand, and that it's best to either get a friend to actually depress the accelarator pedal, or disconnect the battery...can anyone confirm this?...
  • FLY-FPV
  • Member For: 15y 10m 11d
NO that is un true because the throttle is electronic and will only open when car is turned on if car is off and you put the accelerator down the butterfly will not open
  • Moar Powar Babeh
  • Member For: 19y 8m 16d
Are you sure? Mine does.
Either way it doesn't matter if you move the butterfly by hand, just make sure the keys off, otherwise you will be forcing the butterfly to move against the motor.
  • Member For: 18y 8m 11d
I use a toothbrush to scrub the inside
  • Member For: 15y 7m 14d
  On 05/06/2012 at 12:25 AM, broke said:
this throttle body clean job easy on the FG as well?
a lot easier mate, it's easier to get to
  • Member For: 14y 5m 28d
LOL that's in the italian blood...passed down in generations when the old man would scrub his drive way with a tooth brush and then hose it for 3 hours.
love it....
  • Like 2
  • New Member
  • Member For: 13y 28d
  On 09/03/2011 at 4:45 AM, NVT said:
Cheers Sh00t,
Awesome little write-up. There has been a ton of threads recently regarding this, so nice work!
With the TPS/Cam phasing reset - I have read replies supporting both sides so I'm not really sure what it means.
I heard the car should not start with foot to the floor while cranking - My car still starts! What does that mean? Is there something wrong?
Cheers guys, hopefully this gets cleared up :spoton:
Dan
Try turning key to on position then foot flat then crank it over If I remember right otherwise mine would start too.
Also how does this little bit of oil affect anything ????????? Most cars I have owned have had oily TB and never had problems
  • Thooperrrrrrr
  • Member For: 13y 11m 6d
Might prevent it from opening/closing properly due to dirt in the oil? They come clean so I suppose they should stay clean (bought myself some Nulon Throttle body cleaner today from SC, will give it a shot this week when I can)
  • 1 month later...
  • Member For: 15y 3m 29d
are the syptoms of a dirty throttle body and faulty TPS the same?
I am have the same problems: rough idle at random times, car jolts when reversing on cold start up etc...
