ColinT Donating Members 372 Member For: 19y 11m 16d Posted 07/03/11 02:56 AM Share Posted 07/03/11 02:56 AM (edited) Finally travelled 7,500klms and as I did with the BA XR6T I change the oil between the regular 15,000 klm services.Well the story goes, Sunday afternoon.Up on the mates hoist, first time Ive been under the FG.What is the cooler next to the sump plug? Didn't have that on the BA.Possioned the catch drum, removed the sump plug, hot oil up the sleeve.As it drained I thought to remove the filter.Had to use 2 hands on the wrench to get it to move, off comes the filter looking a bit crushed.Pulled out the new filter, AHHHH its not the same as the filter I kept from the BA.The mate took me to Autobarn to buy the correct filter, didn't know it had changed.Got back fitted the filter, installed and tightened the sump plug.Lowered the car poured in approx 7lts of oil.Now came the interesting part. Between the 2 of us we had a hard time seeing what level was on the dip stick, the oil was so clean.If anyone has a suggestion please let me know to make it easier to see.Anyway started it up and all ran okay.The 1 hour I thought it would take took just over 2. Edited 07/03/11 02:58 AM by ColinT Link to comment Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 6m 13d Gender: Male Posted 07/03/11 03:11 AM Share Posted 07/03/11 03:11 AM The cooler next to the sump plug will be the heat exchanger for the Transmission.Doesnt matter if the filter comes out crushed at the base, doesn't affect the top part, I find a very large set of multi grips best for getting oil filters off. Just make sure with the new filter you coat the seal in a bit of oil and dont do it up to tight, just do it up as much as you can with your hands, no need to use a tool on it.Best thing to see the oil is to catch it in the light to see the level... Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 17y 10m 7d Gender: Male Location: Slip Sliding Away Posted 07/03/11 09:02 AM Share Posted 07/03/11 09:02 AM Or run a tissue down the dipstick until it hits the oil and gets wet.Should be able to tell from that.I normally tighten the oil filter till the seal touches then 2/3rds of a turn. Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 4m 12d Gender: Male Location: Southern Highlands NSW Posted 07/03/11 09:23 AM Share Posted 07/03/11 09:23 AM Ive found that 7 litres is too much. Shows full for me using 6 litres. Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 5m 12d Gender: Male Location: Newcastle Posted 07/03/11 09:33 AM Share Posted 07/03/11 09:33 AM I just did mine yesterday, I know it's hard to see the level. 7 ltrs is definately too much and as RHR has said 6 litres is plenty. As you would know now the filter is an AFL101.Benny. Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 1m 2d Gender: Male Posted 07/03/11 10:00 AM Share Posted 07/03/11 10:00 AM I bought 9 of these shipped for $100.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=310294985359&viewitem=#ht_37453wt_820 Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 07/03/11 11:06 AM Share Posted 07/03/11 11:06 AM Definitely 6lt on a change. 7 maybe on a rebuild. My filter was on way too tight. But I doubt they oiled the O'ring at the factory. No oil in the motor yet. Link to comment Share on other sites More sharing options...
