Btr 4Speed To Zf 6 Speed Conversion
maso13
  • Member For: 18y 8m 28d
Alloy pans give case strength and some will aid slightly with cooling but nothing like a trans cooler.
Any 3 speed or glide will require extensive mods to be capable of handling the power these cars produce, standard they are weaker than the 4 speed.
  • Member For: 13y 11m 21d
already got a trans cooler on the ute never goes over bout 180 and when it gets to 180 I take it easy , so do you drive in 60 zones in 3rd ??
  • Member For: 17y 7m 30d
correct. 3rd has a overdrive on it so im sitting about 2000rpm
The trans builder told me so , so I stuck with it havnt had to rebuild it yet, whereas some others havnt lasted not half as long.
Edited by RHR
No need to quote above post. USE FAST REPLY
cheers mate I might leave it as is use all these tips and see how it goes , I guess a rebuild is cheaper than a conversion.
