  • blind leading the blind
  • Member For: 16y 9m 4d
I'm gonna track one down and give it a crack. I get rash from both electric and normal. I have gone to shaving once a week to lessen the irritation. Electric used to work alright until I missed a day shaving then it had no hope
  • I <3 Floods
  • Member For: 13y 10m 14d
MERKUR BARBER POLE 38C Double Edge Safety Razor +BLADES
http://bit.ly/19J0QI4
  • 3 weeks later...
  • Member For: 19y 2m 22d
I only use a cut throat razor. Have done for about 10 years.
You can't beat a nice close shave with a well worked up lather and an uber sharp blade.
  • Expert
  • Member For: 20y 3m 19d
I've shaved once in the past 2 months and that was for a job interview other wise im growing it. Saving heaps
  • Member For: 13y 9m 29d
Hey Pazz you get them from Shaver shop chadstone or something or ebay, Merkur or Edwin Jagger is the goods
http://www.ebay.com.au/sch/I.html?_sacat=0&_nkw=edwin+jagger&_frs=1
I got mine from shaver shop and buy the blades off ebay uk 30 Blades for $21 dollars delivered a blade will last a week or 2 before needing replacement so 30 blades should last like 60 weeks and I just use foam in a can the brush and dish etc is a pain in the arse todo the spray foam is a lot quicker and not that expensive when you conside a pack of like 5 mach 3 blades for a 5 pack is $30 and lasts like a month
These are the blades I have I havent quiet settled on a brand so I just get afew different to try out.
http://www.ebay.com.au/itm/290785073792?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Edited by spinr33
  • 3 weeks later...
  • Member For: 16y 10m 27d
  On 23/08/2013 at 7:54 AM, _Velocity_ said:
Without a bit of practice that bad boy will slit my throat!
It's not as bad as you might think although definitely not something to do when you're in a hurry...
Because you strop it before each shave the blade is as sharp as it can be unlike disposable blades which are sharp for the first shave or two then feel dull.
Also - who doesn't like the idea of owning a quality piece of machinery and using and maintaining it well! If it was all about just 'getting the job done' we would all be driving to work in hyundais....
