Jesse Williams Member 7 Member For: 13y 10d Posted 01/02/12 12:09 AM Share Posted 01/02/12 12:09 AM Got half way through reading these replies and decided to skip the rest, so this may have already been covered.If you change to a high-flow cat, then you will need a tune because the after-cat o2 sensor won't work properly and cause it to lean out, this requiring a tune.Cat-back you won't need to do anything, other than try and refit the after-cat o2 sensor.If you have a BF or BF mkII then the computer will relearn if you install a larger dump pipe.Basically, of you change the cat, you require a tune. Link to comment Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 5m 4d Gender: Male Location: South West QLD Posted 01/02/12 01:40 AM Share Posted 01/02/12 01:40 AM Yes.. Dump and Cat = Tune.. Catback is fine on a stock system.. But on a system where the catback may be providing a restriction (Already modded XR6T's) changing the catback may require a run on the dyno to check AFR's. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 1m 14d Gender: Male Location: SE Melbourne Posted 01/02/12 01:44 AM Share Posted 01/02/12 01:44 AM Got half way through reading these replies and decided to skip the rest, so this may have already been covered.If you change to a high-flow cat, then you will need a tune because the after-cat o2 sensor won't work properly and cause it to lean out, this requiring a tune.Cat-back you won't need to do anything, other than try and refit the after-cat o2 sensor.If you have a BF or BF mkII then the computer will relearn if you install a larger dump pipe.Basically, of you change the cat, you require a tune.The after cat o2 sensor does absolutely nothing apart from throw a code if your emissions don't meet a certain threshold. It does not do anything to the tune or change the way the car runs. The reason for retune after changing the cat is because the increased flow will cause overboost. Link to comment Share on other sites More sharing options...
Barra Donating Members 467 Member For: 16y 1m 22d Gender: Male Location: Toowoomba Posted 01/02/12 02:20 AM Share Posted 01/02/12 02:20 AM The after cat o2 sensor does absolutely nothing apart from throw a code if your emissions don't meet a certain threshold. It does not do anything to the tune or change the way the car runs. The reason for retune after changing the cat is because the increased flow will cause overboost. Agree. Changed my cat not dump and no codes and will only overboost 3 psi max on a cold night if I push it. Getting AFR checked asap though. Link to comment Share on other sites More sharing options...
