n/axr6ute Member 58 Member For: 15y 3m 25d Posted 01/03/11 02:05 AM Share Posted 01/03/11 02:05 AM Hey guys just wondering if anyone can shed some light on my problem, whilst the car is running it is very difficult to change gears whilst the clutch is in - of course.there doesnt seem to be anything wrong with my clutch as it grabs and doesnt slip at all, while the car isnt running its as easy as it always has been to change gears.Maybe the clutch slave cylinder has let go and not engaging the clutch to its full capacity? I'm no expert, any help is greatly appreciated.Thanks, Sam. Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/ Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 12d Gender: Male Location: Zombie Birdhouse Posted 01/03/11 03:04 AM Share Posted 01/03/11 03:04 AM Give Mal Wood a call Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085172 Share on other sites More sharing options...
sam_rigger Member 246 Member For: 14y 3m 16d Posted 01/03/11 11:16 PM Share Posted 01/03/11 11:16 PM Could be that there is air in your system, try getting the clutch re-bled, could be the csc or master cylinder also but I would start with the easy cheap stuff first.I'm tipping though a bleed will fix your problem Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085394 Share on other sites More sharing options...
n/axr6ute Member 58 Member For: 15y 3m 25d Posted 02/03/11 02:08 AM Author Share Posted 02/03/11 02:08 AM Tried bleeding it, no such luck.Bit the bullet yesterday and pulled the box out, went to the local mechanics where he has a new slave on the shelf, the one from my car had about half the amount of movement as a new one. bought it and will be fitting it this arvo.. ill keep you updated as to whether it worked or not.Cheers, Sam. Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085434 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 3d Gender: Male Location: @ my laptop Posted 02/03/11 03:23 AM Share Posted 02/03/11 03:23 AM I would recommend if the csc is out to fit and alloy one, we sell them for $175 and they are a lot stronger then the plastic ones Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085452 Share on other sites More sharing options...
southside Member Member 868 Member For: 16y 3m 28d Gender: Male Location: Radelaide.. Real Posted 02/03/11 12:18 PM Share Posted 02/03/11 12:18 PM Go the T56 :D Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085653 Share on other sites More sharing options...
n/axr6ute Member 58 Member For: 15y 3m 25d Posted 02/03/11 09:55 PM Author Share Posted 02/03/11 09:55 PM Hey guys, for anyone interested I replaced the csc last night and it has no fixed my problem - I did put an alloy one in, as ford quoted $400+ for theres. It's got me beat to what it could be, also thought I'd let you know how this happened, was at the drags, did a burnout, the clutch pedal went rock solid for about 5 seconds, I then had to pump the pedal about 10 or so times to get the clutch working again.Hope that info helps some of the experts as im stumped..Any help is appreciated, Cheers, Sam. Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085686 Share on other sites More sharing options...
southside Member Member 868 Member For: 16y 3m 28d Gender: Male Location: Radelaide.. Real Posted 02/03/11 10:44 PM Share Posted 02/03/11 10:44 PM sounds like some internal damage there.... laying skids with a T5 isnt the best thing for those little boxes, id recommend going to a Trans specialist and getting it opened up... if the problem is still hanging around after replacing the CSC or anything, dear I say a rebuild or a new gear box otherwise u could get your clutch system checked out??? is it the standard one? I had a fair few issues with mine! so I decided just overloading it till it snapped the plate haha now I got a Malwood option 3 and its holding up to my heavy driving style with the tune I havegood luck anyway mate! Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085691 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 5d Gender: Male Location: Victoria Posted 03/03/11 12:26 PM Share Posted 03/03/11 12:26 PM Sounds like syncro damage.They can be repaired easy enough. A T5 isn't a complicated box. Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1085927 Share on other sites More sharing options...
n/axr6ute Member 58 Member For: 15y 3m 25d Posted 07/03/11 11:20 PM Author Share Posted 07/03/11 11:20 PM Thanks guys for the info. I thought it might be synchro's aswell, but how it happened didnt seem like it could support that..Now with the car back together I noticed the higher I rev the engine the harder it gets to puch my clutch in. Car is drivable but difficult.Thanks, Sam. Link to comment https://www.fordxr6turbo.com/forum/topic/73556-having-trouble-selecting-gears/#findComment-1087111 Share on other sites More sharing options...
