boost-kid Member 80 Member For: 16y 7m 24d Posted 25/05/09 01:56 AM Share Posted 25/05/09 01:56 AM (edited) will a dynamat xtreme pack be enough to cover entire boot including boot lid and the front doors in a sedan?? Edited 25/05/09 02:02 AM by boost-kid Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-880943 Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 7m 9d Location: Mackay QLD Posted 25/05/09 09:48 AM Share Posted 25/05/09 09:48 AM (edited) which pack?door pack? bulk pack? trunk kit?you would need a bulk kit at least to cover all that Edited 25/05/09 09:48 AM by sicklaser Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-881107 Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 17y 2m 1d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 25/05/09 12:19 PM Share Posted 25/05/09 12:19 PM :banghead:Do you really want to cover the 'WHOLE' boot area? Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-881258 Share on other sites More sharing options...
boost-kid Member 80 Member For: 16y 7m 24d Posted 25/05/09 01:26 PM Share Posted 25/05/09 01:26 PM sorry, yes im talking about the bulk packwouldnt covering as much as you can be better???the more you cover the less noises,rattles and sound being lost Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-881278 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 7m 10d Gender: Male Location: Mildura Posted 25/05/09 02:05 PM Share Posted 25/05/09 02:05 PM yes the bulk extrme kit will just cover the underside of the bootlid, and the front doors.... I doubt youll get much else out of it though! Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-881295 Share on other sites More sharing options...
boost-kid Member 80 Member For: 16y 7m 24d Posted 26/05/09 02:35 AM Share Posted 26/05/09 02:35 AM (edited) do you mean the underside of the boot and boot lid?if it will only cover the front doors and a little bit of the boot,that's crap!does anyone have photos of there installs of there boots and front doors? so I can get a rough idea of specific areas to cover in the boot and front doors, getting the most out of the bulk pack Edited 26/05/09 02:43 AM by boost-kid Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-881433 Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 7m 9d Location: Mackay QLD Posted 27/05/09 09:33 AM Share Posted 27/05/09 09:33 AM for the doors you need to put a few strips inside the outer door skin. make sure you get some on the skin right behind where the woofer is. once you have done the inside of the outer skin you need to cover up all the inspection holes in the door frame. nearly sealing the door up.put some more on the top of your parcel shelf and do your boot lid. there are other dynamat products more designed to be noise barriers that would be better under your boot carpet than dynamat extreme. Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-882091 Share on other sites More sharing options...
Daniel Member 299 Member For: 21y 9m 12d Gender: Male Posted 27/05/09 10:18 AM Share Posted 27/05/09 10:18 AM What is the IDEAL product to put in the boot to cut out the road/exhaust noise?I am not trying to improve SQ or SPL etc How hard is it to remove the door skin? Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-882143 Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 7m 9d Location: Mackay QLD Posted 28/05/09 08:35 AM Share Posted 28/05/09 08:35 AM Quote How hard is it to remove the door skin?you cant remove the outer skin. you will need to take the door trim off and wind the window up and work thru the inspection holes. after the outer skin is done then cover up the inspection holes.I think they do a product called 'dynaliner' that is more of a sound barrier. dynamat mainly stops panel resonation. Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-882460 Share on other sites More sharing options...
boost-kid Member 80 Member For: 16y 7m 24d Posted 28/05/09 09:43 AM Share Posted 28/05/09 09:43 AM what sort of result will I get from doing the doors?and after doing the boot,the little rattles and vibrations should be decreased but will bass be increased and not as much lost? Link to comment https://www.fordxr6turbo.com/forum/topic/73550-dynamat/page/2/#findComment-882490 Share on other sites More sharing options...
