What Have I Done? - Wife's 03 Ba Xr6 Turbo
Jeckyl
  • Member For: 14y 1m 7d
G'day brand new to this so he we go...
Wife's car is a 2003 BA XR6T 4spd auto
clocked up 120 klms
got a little bored and fitted the following..
1, CAI - ss induction big mouth
2, BF F6 intercooler
3, CES 3.5inch dump pipe and 100 cell cat fitted upto stock tail section of the exhaust
I think I've gone backwards as the power is slugish and I'm a victim of over boost around 4000 rpm..
I've just ordered a SCT X3 flash tuner from intune motorsport will this help my slugish overboost problem?......please help
  • Member For: 16y 11m 18d
Read up on Intune on this site. Then get a Custom tune asap. Throw in some injectors and Valve springs and you'll see over 300rwkw. With a Generic tune you will probably make 220rwkw for a weeks thenitll all go pear shaped.
  • Formerly EGOBFXR6
  • Member For: 17y 1m 5d
Yeah Jeckyl,
There are a number of mods that you can't just bolt on... Intakes, injectors, exhaust etc...
The ECU needs to be re-adjusted by a proper tuner. He will dyno the car and make the necessary adjustments to your car (Otherwise known as the custom tune)
You need the XCAL for storing and transferring between tunes. You will need a tune asap so drive her really gentle and keep her off boost. The less you driver her the better...
Hope that has helped mate :spoton:
Good luck
Generic tunes are just a rough tune made up on one car, and are never suited well to another. Theres lots of horror stories floating around from generic tunes. Not so many these days as most people steer clear. Poor tune = damage to motor.
At the moment your probably overboosting, is it going into limp mode? Do you have an engine light on?
  • Formerly EGOBFXR6
Pear shaped as a generic tune is pretty crap - Not very good on your car...
I'd also say he'd be referring to your gearbox exploding :innocent: (Or needing a rebuild/strengthen)
What gearbox are you running?
gearbox standard 4spd..
No engine light of anykind...
the first time it overboosted the engine got it self into a spasm.... so I shut it off and let her sit for a minute.....once I hit the key it started up fine and drove normal with out any engine warning light..cheers
  • Formerly EGOBFXR6
I'd say you'll just need a good retune to have the issues sorted.
You will need some valve springs if you want to chase much more power and you may look into a bigger cat/exhaust to also lower exhaust pressure. You may then look into Intercooler/piping options - It really depends on what power you want, how much you have to spend and how reliable you want it to be.
The 4 speed are a good box but do be prepared to have it rebuilt/strengthened if you run big power and/or if you are a very 'spirited' driver. A trans cooler is also very good insurance for your transmission.
Sorry if this post is a little 'to the point' with upgrades and dramas, but it's happened to a number of T owners and it's better that you know now :spoton:
Cheers mate, let us know how you do,
Dan
