Help! Warning Lights And Headlights Gone
BailZ
  • Member For: 18y 2m 12d
Hi guys,
Haven't had much trouble with my car recently, and gave it a bit of a hard drive up the coast on a hot day - the radiator fluid boiled out of my new o'flow tank and now my headlights have gone, the high beams light is on, the indicator lights are lit (dimly) and the ABS light is on?
I am guessing its a fuse, but I have no idea where to start?
  • Member For: 19y 9m 5d
Water in the engine bay or water vapour will do funy things to electricals...I dont think its a fuse...normally the water should evaporate and things should go back to normal...sometimes if the water is trapped the problem can keep re occuring...
I think chances are it will go away the more you drive it as the heat will evaporate the water
Yeh cheers - It ended up being a bad earth - the screw rattled loose and that caused (somehow?) the radiator to malfunction.
