straughsberry Donating Members 1,846 Member For: 17y 10m 17d Gender: Male Location: Broady, Melbourne Posted 24/02/11 03:16 AM Share Posted 24/02/11 03:16 AM +1 for high line pressures.I had the same problem after getting my BTR built. Valve body was not modified. Line pressures in the tune had been modified for the stock box and with the new box, line pressures were increased. It began to take off in second 30%-40% of the time. We turned down line pressures in the box until it went away. On the very odd occasion, it will still take off in second. Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1083923 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 3m 4d Gender: Male Posted 24/02/11 04:58 AM Share Posted 24/02/11 04:58 AM Are you guys talking about reducing the pressure of the s5 solenoid by turning it down orreducing the spring pressure of the main pressure relief valve in the valve body by removing the extra shims installed when it was modded Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1083962 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 10m 17d Gender: Male Location: Broady, Melbourne Posted 24/02/11 05:05 AM Share Posted 24/02/11 05:05 AM For me, reducing the pressure of the s5 solenoid by turning it down. I think the combination of increased line pressure in the tune and s5 was causing it to take off in second. Slight turn down of the S5 pretty much fixed it for me. My box shifts firmer in tippy than in D as line pressures in tune are higher in tippy. So when I'm playing, I only play in tippy. Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1083963 Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 6m 26d Posted 24/02/11 11:13 AM Author Share Posted 24/02/11 11:13 AM (edited) +1 for high line pressures.I had the same problem after getting my BTR built. Valve body was not modified. Line pressures in the tune had been modified for the stock box and with the new box, line pressures were increased. It began to take off in second 30%-40% of the time. We turned down line pressures in the box until it went away. On the very odd occasion, it will still take off in second.Hi straughsberry, my transmission builder turned down the line presures back to standard an we still had the same out come,right now im thinking to replace my tps sensor, voltage sensor, to see if it may make a difference, as this is known to happen when a voltage sensor is faulty, acording to my workshop manual. Edited 24/02/11 11:17 AM by CCCC Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1084123 Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 14y 7m 20d Posted 24/02/11 10:33 PM Share Posted 24/02/11 10:33 PM If you have an xcal 2/3 run a diagnostic to c if it has logged any faults electronically. Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1084195 Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 6m 26d Posted 25/02/11 01:08 PM Author Share Posted 25/02/11 01:08 PM Hi mate, yea iv all ready tryed with the xcal, an it didnt record any faults, then an other bloke used his scanner an the only thing it recorded was seatbelts, it looks like its going to be a pain in the ass now for me trying to solve this drama,I might get a tuner to adjust the line pressures on the computer lower to see if that can make a change.I dont understand why but it gets all gears while I use the tip control, but soon as I push it in drive,it takes off in second. Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1084376 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 8d Gender: Male Location: @ my laptop Posted 26/02/11 02:08 AM Share Posted 26/02/11 02:08 AM one of the ones we saw, we put everything auto back to stock and it still did it until the auto guy rectified the auto itself. Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1084443 Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 6m 26d Posted 26/02/11 12:41 PM Author Share Posted 26/02/11 12:41 PM one of the ones we saw, we put everything auto back to stock and it still did it until the auto guy rectified the auto itself.Hi ratter, yesterday we put the standard tune back in the car, an it didnt change a thing, would you know if the cruise control an my back brake lights would have anything to do with how my gearbox is behaving, they seem to have a mind of its own, because they work sometimes, an then they stop working.Another thing ratter with the cars that you have seen with the similar dramas that my gearbox is doing, did they have all gears from 1 to 4 in tiptronic mode, or did they miss first gear?If I cant sort this problem,do you thing the next best thing to do would be changing the valve body to standard to see what happens?thanks for your help ratter Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1084613 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 11m 18d Gender: Male Location: Aspendale, Vic. Posted 26/02/11 06:02 PM Share Posted 26/02/11 06:02 PM yes. remove the valve body and put a stock one back in. I still think you have a manualized valve body that's causing the issue. Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1084640 Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 14y 7m 20d Posted 26/02/11 08:23 PM Share Posted 26/02/11 08:23 PM This cruise issue and back brakes sounds like its in the Tune. Have you contacted CV yet? Link to comment https://www.fordxr6turbo.com/forum/topic/73454-btr-4-speed-tripping-out/page/2/#findComment-1084644 Share on other sites More sharing options...
