CCCC miso xr6 Donating Members 317 Member For: 16y 2d Posted 23/02/11 08:49 AM Share Posted 23/02/11 08:49 AM Hi everyone, I thought I post this up, just in case the problems that I have, as happened to someone else or someone would know where best sould I start, before I start tearing the electrical parts off my car, but anyways this is my problem, when car is in drive (btr 4 speed) the car takes of in 2nd gear, but when in sports mode (manual shifting) I get all my gears, the gearbox is modyfied an it as a 3000 rpm converter, car is tuned an it as 300kw at the wheels, now my transmission builder has pulled the box apart just to rule out it is not the gearbox causing my problems, me an him have came to a conclusion an we think that it may be a tps sensor that has failed, or my computer as tripped it self out, so guys all I wanna know is has anyone had a similar problem an fixed it? how did you fix it?all your help would be greatly apreciated.thanksmic Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 14d Gender: Male Location: @ my laptop Posted 23/02/11 10:30 AM Share Posted 23/02/11 10:30 AM Seen it before and it has always been the trans has too much pressure from one of the solenoids. Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 2d Posted 23/02/11 10:52 AM Author Share Posted 23/02/11 10:52 AM hi ratter thanks for the reply, but with the solinoids we tryed adjusting them an that failed, so them we put brand new ones in an still had the same problem, so then after that, we ripped the gearbox apart an it was all perfect. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 14d Gender: Male Location: @ my laptop Posted 23/02/11 10:55 AM Share Posted 23/02/11 10:55 AM has the valve body been modified? Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 2d Posted 23/02/11 11:17 AM Author Share Posted 23/02/11 11:17 AM (edited) the valve body has been modified, this problem that I have now just started about two weeks ago, but before that it was shifting hard in all the gears for about 5000ks without any problems, until out of no were it just started to take off in 2nd gear, but in manual mode it is fine, it shifts all gears. Edited 23/02/11 11:59 PM by Dagabond Quote removed.... Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 4m 24d Gender: Male Location: Aspendale, Vic. Posted 23/02/11 11:20 AM Share Posted 23/02/11 11:20 AM usually for car to start in 2nd the btr would need a manualized valve body. With manual gears, can you take off in second? If its an s5 solinoid an error would pop up. Again, depends what diagnostic computer you are using. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 14d Gender: Male Location: @ my laptop Posted 23/02/11 11:21 AM Share Posted 23/02/11 11:21 AM the valve body has been modified, this problem that I have now just started about two weeks ago, but before that it was shifting hard in all the gears for about 5000ks without any problems, until out of no were it just started to take off in 2nd gear, but in manual mode it is fine, it shifts all gears.You may need to try a standard valve body to check, I'm not a trans guy, but have seen this a couple of times and it has always been related to too much pressure and not enough relief area for the oil flow. Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 2d Posted 23/02/11 11:29 AM Author Share Posted 23/02/11 11:29 AM Thanks for your help ratter, I will be checking that. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 14d Gender: Male Location: @ my laptop Posted 23/02/11 11:29 AM Share Posted 23/02/11 11:29 AM Good luck, let us know the outcome Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 2d Posted 23/02/11 11:47 AM Author Share Posted 23/02/11 11:47 AM no propz mate, thanks for your help. Link to comment Share on other sites More sharing options...
