Torkfreik Member 19 Member For: 13y 8m 25d Gender: Male Location: Mornington Peninsula, VIC Posted 18/02/11 04:57 AM Share Posted 18/02/11 04:57 AM Hi guys/gals. Just after info concerning the Force 6 from owners. Firstly, what turbo do these run? Similar to the XR6T Garrett? Also. Intercooler size/dimensions. I'm looking @ purchasing a Force 6 @ present & quite frankly, although I know the XR6T & the XR8, even the SC'd 8, I know little about the Force breed? Any info will be very appreciated Link to comment Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 15y 4m 23d Gender: Male Location: E. Maitland Posted 18/02/11 05:04 AM Share Posted 18/02/11 05:04 AM just a fancier lloking typhoon mate, same turbo etc Link to comment Share on other sites More sharing options...
Torkfreik Member 19 Member For: 13y 8m 25d Gender: Male Location: Mornington Peninsula, VIC Posted 18/02/11 05:48 AM Author Share Posted 18/02/11 05:48 AM (edited) Thanks! I shoulda known this seeing as though the power is the same. Spose you ask dumb questions when your not sure lol. Guess the question shoulda been, is the turbo the same in the 270kw BF series as the 240/5kw BA? GT3540R or bigger? I don't know much concerning the BF? Is it just an ECU upgrade in the newer series like is it chipped? I know the intercooler is larger. Is that about all? Edited 18/02/11 07:52 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1m 19d Gender: Male Location: Perth Posted 18/02/11 07:49 AM Share Posted 18/02/11 07:49 AM BA/BF all have the same turbo FPV or not. BF's got better cams and a smarter VCM hence the extra gruntInjectors are the same across all models too.Many many non FPV owners have been sucked in and bought "typhoon" injectors that are the same as the ones they already had Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 5m 17d Gender: Male Location: Melbourne Posted 18/02/11 08:04 AM Share Posted 18/02/11 08:04 AM Mate if you can get a good low kay Force 6 then get it. Easily the best B series car there is. 1 Link to comment Share on other sites More sharing options...
Torkfreik Member 19 Member For: 13y 8m 25d Gender: Male Location: Mornington Peninsula, VIC Posted 18/02/11 08:11 AM Author Share Posted 18/02/11 08:11 AM Thanks guys. The rare factor is certainly a consideration. Everything seems to devalue quick as look @ it today Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1m 19d Gender: Male Location: Perth Posted 18/02/11 09:51 AM Share Posted 18/02/11 09:51 AM Mate if you can get a good low kay Force 6 then get it. Easily the best B series car there is. As much as I hate too admit it Lil Tabby is correct. Def the best B series. Rare because Ford pump the price 10 to 15K too high Link to comment Share on other sites More sharing options...
Torkfreik Member 19 Member For: 13y 8m 25d Gender: Male Location: Mornington Peninsula, VIC Posted 19/02/11 01:11 AM Author Share Posted 19/02/11 01:11 AM (edited) Sorry if I'm labouring this a tad but, next car I purchase is kinda for keeps (a while anyway).The flash right up on the 270kw FPV's note the turbo spool & efficiency as quite dramatic. Very early spool & impressively high torque figures, like 1500, with full torque range from 2000-4500 or so rpm. That's quite impressive afaik......my question is are the BA/BF XR6T's similar in regards to this performance? If it's the same turbo & similar set up. I note the FPV's had a larger intercooler which would tend to produce power up top & not down low. Would this give the 240/245kw BA/BF's even quicker spool? More power through lower rev range? I guess my main point is surely the extra output the FPV's produce should have nothing to do with low down grunt but moreso high-end power? If this is so, the 240kw BA's for instance should have similar peppy everyday street performance as the higher output 270kw FPV's? Yeah??? Can someone give me a heads up on the stock BA model's performance (low down/early spool wise), this will help me decide on next car quite....... Edited 19/02/11 01:13 AM by Torkfreik Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 9m 24d Gender: Male Location: Christchurch, New Zealand Posted 19/02/11 01:26 AM Share Posted 19/02/11 01:26 AM Basically the B series are identical apart from small changes inside the engine between the FPV and Non (springs and stuff). Turbos are the same size, power in the non is 240 or 245kw depending on model, they also achieve max torque at 1800-5000 which I think is somewhere around the 450 or 480 nm mark. Whereas the FPV has 270kw I dont know the torque value but achieves it the same where its on tap almost straight away and is there throughout the rev range really.Hope that helps they are fantastic to drive everyday manual or auto. Also great when towing. Link to comment Share on other sites More sharing options...
Torkfreik Member 19 Member For: 13y 8m 25d Gender: Male Location: Mornington Peninsula, VIC Posted 19/02/11 02:02 AM Author Share Posted 19/02/11 02:02 AM (edited) Thanks. Definatley helps as I thought so since learning they are all much the same set up really. I just needed confirmation. My past boosting experience is centered more on 3.0L platforms & I've only really researched how to get big top end power which really results in poor low-down grunt. With big power in a 3.0L Nissan engine, if the turbo spools well @ 2500, your impressed. That is with the GT30R/3540R's, as in the Fords, but I'm pretty new to the XR6T's larger 4.0L engines so, obviously the GT35's are definately not a huge turbo. Begs the wonder what they would be like with the smaler .84 turbine housing instead of the stock 1.06? They'd be mean down low...... Edited 19/02/11 02:02 AM by Torkfreik Link to comment Share on other sites More sharing options...
