Weaponxr Donating Members 624 Member For: 14y 20d Gender: Male Location: Melbourne Posted 15/02/11 12:23 PM Author Share Posted 15/02/11 12:23 PM Basically from what I know its got a noisey bearing. When I turn the car off I hear the noisey wind down. My thoughts are leaning towards that screen filter on the oil intlet feed. I want to get it early so I dont screw anything.So you think I can just fix the bearings rather than buying a new cartridge?Anyone recommend a place to fix it? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,079 Member For: 16y 8m 22d Gender: Male Location: Melbourne Posted 15/02/11 12:23 PM Share Posted 15/02/11 12:23 PM I just replaced the cartridge on my broken turbo (oil starvation for sure, completely snapped the rotating shaft, separating the turbine & compressor wheel) with this replacement cartridge. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110647498377#ht_1772wt_1148Works a treat with the standard housings and only took about a week and a half to arrive from the states. Only recommendation I have in the changeover is to make 100% sure on your alignment of both housings so all your lines and connections go together smoothly:) had a few silly problems sorting that out. Keith Link to comment Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 15y 6m 12d Gender: Male Location: E. Maitland Posted 15/02/11 12:26 PM Share Posted 15/02/11 12:26 PM we get the rough end of a pineapple here, even 895 US is too dear. IIRC these things are built in Mexico and then marked up to a ridiculous degree. Link to comment Share on other sites More sharing options...
F6turbo Member 172 Member For: 18y 6m 28d Gender: Male Location: Sydney Posted 16/02/11 08:08 AM Share Posted 16/02/11 08:08 AM Basically from what I know its got a noisey bearing. When I turn the car off I hear the noisey wind down. My thoughts are leaning towards that screen filter on the oil intlet feed. I want to get it early so I dont screw anything.So you think I can just fix the bearings rather than buying a new cartridge?Anyone recommend a place to fix it?Yes if its as you describe it. Take the turbo off and take it to a turbo specialist. Link to comment Share on other sites More sharing options...
phantom6 Donating Members 146 Member For: 16y 8m 17d Gender: Male Location: Melbourne, S.E Posted 16/02/11 10:21 AM Share Posted 16/02/11 10:21 AM guys im selling (for a mate) a hiflow 35/40 (custom from gcg 3566r) for sale $1350 inc postage, check it out in classifieds Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 8d Gender: Male Location: Perth Posted 16/02/11 10:31 AM Share Posted 16/02/11 10:31 AM FFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU........................... Where was this turbo last month when i had too replace mine..???Can highly recommend the GT3566R and this price is just under 1/2 of new. Be prepared too spend $300 to $500 to get it too fit nicely with the 4" intake Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,079 Member For: 16y 8m 22d Gender: Male Location: Melbourne Posted 16/02/11 01:02 PM Share Posted 16/02/11 01:02 PM I did call around to quite a few turbo specialists to see what the cost would be, most were a little high... but I found that ETM (Extreme Turbo Manifolds) does a good value recondition of your turbo for you (give Leigh a call for a quote, or send him a PM).He also does an external wastegate to your existing dump pipe if you so choose to go down that pathway for modification, but of course at an extra cost. Link to comment Share on other sites More sharing options...
Weaponxr Donating Members 624 Member For: 14y 20d Gender: Male Location: Melbourne Posted 16/02/11 01:44 PM Author Share Posted 16/02/11 01:44 PM Im thinking about taking it to Rotomaster in calaroo on the hume highway (sydney road) Link to comment Share on other sites More sharing options...
JK89 Member 56 Member For: 14y 22d Posted 22/02/11 10:28 AM Share Posted 22/02/11 10:28 AM Alot of turbo problems especially with the factory garrett gt35r are the bearing inlet holes which feed the bearing pack. they do not always line up with the machining of the cast housing. I have seen many that do not line up in thus starving the turbo of oil. Good and obvious way to tell is hot spots on the actual bearing pack. I would highly recommending using a mr turbo gt35r bearing replacement cartridge. As the bearing system is different, in speaking so the bearing holes align 100% to the bearing carrier which feeds the bearings themselves. Also you will gain around 15% percent on spool response, since the bearings are aerograde space quality. Ie lighter, stronger and harder then standard steel bearings. Cartridges are retail of around the $1250 mark and are all assemebled and machined in australia. Once doing so as many have said change the oil in line to a braided line. will save you a lot of headaches in the future. Do not listen to ford you must warm up and cool down you turbo vehicle and change the oil every 5000km. .70AR comp covers and wastegate porting are also a good option to do if the turbo is off the vehicle as everyone knows they are not a fun job to remove and put back on!any questions just pm mecheersJK Link to comment Share on other sites More sharing options...
timboco Member 9 Member For: 14y 5m 18d Posted 23/02/11 01:21 AM Share Posted 23/02/11 01:21 AM I am wondering what prices I would be paying to recondition my turbo. I believe that its mainly the bearings that's noisy but the wheels arent hitting or anything. I have had a couple of quote to get it done which have ranged from $1600 to $2200. Are there any shops here that would look after us, etc.Anyway advice would be great.Im also considering getting the actuator and flapper done while its off the car, might as well.Thanksthere are new cores on the australian ebay site for $990.00 including a new oil filter screen Link to comment Share on other sites More sharing options...
