chook Member 30 Member For: 14y 9m 30d Gender: Male Posted 15/02/11 05:49 AM Share Posted 15/02/11 05:49 AM To be honest I had the same problem in mine and I have put bilsteins in H&R springs bushes done by ford and now she just skates without any axle hop... Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 17d Gender: Male Location: Gold Coast Posted 15/02/11 06:45 AM Share Posted 15/02/11 06:45 AM (edited) So this explains the floppy rear end of the car. What part/s exactly should be replaced?A couple of ways to fix. My choice is not to change springs because I don't want to firm up the ride - shocks maybe. However, that seems to work. The fundamental problem is the 'spongy' rear diff bush. That and the control blade ones are too soft. The whole thing not only flogs up and down but backwards and forwards when tramp is occuring. Upgraded control blade bushes minimise front to back movement and a better diff bush reduces up and down. My mate at pedders has fixed heaps of these and belives the best option is to do both. One step further is to replace the inner diff bushes but then you are really firming it up and may break something else - diff hat, tailshaft. I'll be going with the superpro versions 'cause I don't want noise. Cheers, Bomber. Edited 15/02/11 06:46 AM by bomber Link to comment Share on other sites More sharing options...
JP300 Donating Members 842 Member For: 19y 5m 15d Gender: Male Location: Sydney Posted 18/02/11 07:38 PM Share Posted 18/02/11 07:38 PM Sorry to dissapoint guys but I've got all of the Superpro bushes put in on the rear of the manual FG and it still tramps like a mofo !! Link to comment Share on other sites More sharing options...
dre Resident idiot. Donating Members 2,068 Member For: 14y 5m 8d Gender: Male Location: Melbourne Posted 18/02/11 08:25 PM Share Posted 18/02/11 08:25 PM I don't think spring and shocks are the answer. It still feels like it moves a little left to right as I'm pushing through a bend (on those days when I get traction) Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 17d Gender: Male Location: Gold Coast Posted 18/02/11 08:45 PM Share Posted 18/02/11 08:45 PM Most seem to have fixed it with the replacement bushes and it will solve the movement issues. Worst case springs and shocks as well but without replacing the bushes, you're treating the symptoms - not the cause. Link to comment Share on other sites More sharing options...
absmith New Member 18 Member For: 16y 10m 13d Posted 27/03/11 09:06 AM Share Posted 27/03/11 09:06 AM Hello All,I have an FG manual XR6T sedan. I found the axle tramp very inhibiting especially in the wet, even the slightest bit of wheel spin turned into a severe banging in the rear. I basically had to baby the car around to prevent the issue. My fix went like this;1. inspected all of the bushes under the car, found the centre rear diff bush torn. This was not too obvious, only noticeable if a screwdriver was inserted into the voids of the bush to spread them then the split became obvious.2. Installed centre diff bush insert from Pedders, did this without removing the rear sub frame (slotted the washer they gave me to go over the bolt). This approach did absolutely nothing to help.3. Installed superpro control blade bushes, no difference.4. Installed superpro pinion support bushes and the centre diff bushing (removal of sub frame required), this fixed about 70% of the issue, huge difference.5. Put new tyres on the rear to replace the original equipment Dunlop's, just cheap 245/40/18's. Problem completely gone.The car will now skate on wet surfaces at any time without tramp.Bushes cost around $450 for the control blade, pinion support and centre diff bush. Hope this helps.4. Link to comment Share on other sites More sharing options...
