n/axr6ute Member 58 Member For: 15y 3m 24d Posted 14/02/11 01:13 AM Share Posted 14/02/11 01:13 AM Hey guys just wondering, if I buy he 1" blocks from ebay which have the warning about needing over 17" rims, does that actually count if I already have lowered springs? only ask is I go to the drags every now and again and use my 16" rims to burn the rubber.any help is appreciated, cheers Link to comment https://www.fordxr6turbo.com/forum/topic/73265-lowering-blocks/ Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 9m 24d Gender: Male Posted 14/02/11 01:51 AM Share Posted 14/02/11 01:51 AM They dont have the clearance, as the block needs to sit inside the rim.You've got a performance car, dont skimp out and buy cheap lowering blocks. Get it reset properly. Link to comment https://www.fordxr6turbo.com/forum/topic/73265-lowering-blocks/#findComment-1080907 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 11d Gender: Male Location: Christchurch, New Zealand Posted 14/02/11 02:48 AM Share Posted 14/02/11 02:48 AM They fit inside 17s with maybe 10mm to spare. Reset the leaves as mentioned is better option. Link to comment https://www.fordxr6turbo.com/forum/topic/73265-lowering-blocks/#findComment-1080927 Share on other sites More sharing options...
rad Donating Members 48 Member For: 19y 1m 18d Gender: Male Location: NZ Posted 14/02/11 04:23 AM Share Posted 14/02/11 04:23 AM I put sl king leafs in my au wagon (I think same set up as the utes) then put some 30mm blocks in as well as wasn't low enough for me.have 17" bf rims and have about 15mm clearance from wheel rim to bottom shock mount so with 16" wheels would be a close fit.I don't see a problem using blocks as long as they have the right locating holes Link to comment https://www.fordxr6turbo.com/forum/topic/73265-lowering-blocks/#findComment-1080944 Share on other sites More sharing options...
