Superlow Coils For The Xr6t
Guest cul08r
  • Guests
I'm lowering the XR6T (sedan) and want to drop it quite substantially. I know there are a few ppl here who have done it, and I am after ACCURATE measurements for the purpose of comparison.
I think this topic is elsewhere, but not in the detail I am chasing.
Could ppl please write below or PM or email me, with all the following details.
MANUFACTURER: e.g. Kings, Lovells, Herrod etc.
Spring Code: e.g. Superlow maybe KSFL xxx
Front before:
Front after:
Rear before:
Rear after:
Measuring from: e.g. Guard lip to centre of hub (rim) or guard lip to bottom of rim etc. If measured to the rim, pls include rim size, as the measurement will change if you are running 17's, 19's etc.
Thanks
Andrew
https://www.fordxr6turbo.com/forum/topic/7323-superlow-coils-for-the-xr6t/
  • Member For: 21y 8m 26d
  TURBO4LT said:
Ive got King springs and measure from lip to centre of hub
Front = 350
Rear = 355
Yeah I've got the same springs
350mm front
355mm rear
If you purchase springs that are as low as this then you'll have to trim the rear bump stop type device that's attached to the lower swing arm on the rear suspension.
Ride isn't too harsh just right.
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 10m 9d
what do they equal 1 inch 1/12 inch ??? as you have to order the springs before you fitt them
  • Flaccid Member
  • Member For: 21y 11m 10d
  Quote
NT TURBO Posted on Nov 6 2003, 10:28 PM
  Hey any replies post'em here to, there's more who are interested
No...not YOU NT?
why would you do such a thing?
Guest 56Mainline
  • Guests
I think I posted the following elsewhere...but here goes again:
18" factory rims & tyres, measurements from bottom of rim to centre (lowest point) on guard.
Before Front = 610mm
Before Rear = 620mm
Fitted Kings Springs (no caster kit) part #'s KFFL-57SL (fronts) & KFRL-68SSL (rears).
After Front = 580mm (ie dropped 30mm)
After Rear = 590mm (ie dropped 30mm)
Also told that they will further "settle" or "sag" another 5~10mm
  • Bloody Orange Team (BOT)
  • Member For: 21y 10m 10d
Just measured it on my car.
From guard lip to middle of hub.
340mm front
345mm back
(give or take 10mm, due to not so level surface in the garage when I measured it)
Herrod Suspension kit. Springs and adjustable camber. Dunno the brands though.
