Plazmaman Surge Tank And Plenum Install
  • Member For: 14y 11m 9d
Here are a couple pics of the install along the way, as Brandon said if you follow supplied instructions supplied its not to hard. The picture with the wires sticking out, there's a pink wire more pulled out than the rest which is the trigger wire to the pump which we just tapped into (hint for finding it was set your multimeter to beep when it creates a circuit, pull out the fuel pump relay out of the relay block then pierce into the wire slightly with one end and touch into the terminals where the relay pushes into and if it beeps its the fuel pump trigger wire) . All tests were performed along the way with the help of a multimeter and yeah at the end all was sweet. Sorry we didnt get more pics kept forgetting about the camera along the way and just took pictures at stages but if you need any questions asked where happy to answer them to the best of our ability.
Edit: Will also post up pics of the plenum install when we do that on sunday.
post-38702-0-42333400-1297333249_thumb.j
post-38702-0-59282700-1297333257_thumb.j
post-38702-0-31841600-1297333275_thumb.j
post-38702-0-26895400-1297333289_thumb.j
post-38702-0-21624200-1297333300_thumb.j
post-38702-0-14176400-1297333308_thumb.j
Edited by sneeze_monkey36
  • Member For: 14y 10m 27d
Well drove around for a while tonight and I couldnt tell any different and correct me if im wrong but wouldnt the computer be able to tell if there was more fuel going in by the instantainous fuel measurement, as mine has not changed at all after the install and doesnt smell fuely or anything like that
