spine Donating Members 642 Member For: 19y 10d Gender: Male Location: Footscrayastan Posted 09/02/11 06:14 PM Share Posted 09/02/11 06:14 PM On 09/02/2011 at 10:14 AM, shananp said: you can change between methanol and unleaded so good as your injectors can cope with the more fuel needed for methanol.My car has a 98 tune a e85 tune and also a methanol tune and every tune works great . just talk to dion *Beep* and he will sort you out What size are your injectors? and when you run meth, is it a 100% mix? Link to comment https://www.fordxr6turbo.com/forum/topic/73171-straight-e85-v-straight-methanol/page/3/#findComment-1079731 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 3m 14d Gender: Male Location: QLD Posted 09/02/11 06:15 PM Share Posted 09/02/11 06:15 PM Why go through all that hassle if only aiming at 450-500rwkw, those power figures can be had from running a good setup?Be easier to run nos on the street and get better results safer. I was looking at running methanol years ago for a Stroker Windsor in a XY GT Rep I had, and learnt it wasn't worth the hassle, didn't know about all the toxic problems except that it would chew holes in anything that wasn't compatable, eg hoses & seals. And the fact I would need to double up on my full Fuel system, the hassle of flushing it to run pump etc. If you want to run it, just do a stand alone methanol injection setup that only triggers with WOT to give you that extra power. You could run more boost and timing by doing so for more power. Still not legal and still dangerous, and you would need a tuner who knows what they are doing to get it right. A safer option is to run water injection, nor anywhere effective as Methanol but it will allow you to run a little more boost and timing as well you could set it up to run a water spray for intercooler at same time. It's legal and safe as well easier to tune. I have never run Methanol or a water injection setup, im only relaying what I have heard over the years. I may be incorrect so best talk with a expert on this. Link to comment https://www.fordxr6turbo.com/forum/topic/73171-straight-e85-v-straight-methanol/page/3/#findComment-1079732 Share on other sites More sharing options...
PSI40L Member 175 Member For: 22y 4m 11d Posted 10/02/11 09:55 AM Share Posted 10/02/11 09:55 AM dont know what the stoichiometric values will be when doing a mix of meth and petrol but I wouldnt trust the tune on a mix fuel Link to comment https://www.fordxr6turbo.com/forum/topic/73171-straight-e85-v-straight-methanol/page/3/#findComment-1079991 Share on other sites More sharing options...
