Alex86 Member 2 Member For: 14y 26d Posted 08/02/11 03:38 AM Share Posted 08/02/11 03:38 AM Hi there. I’m new on the forum and I'm looking for some information about what to look out for in a second hand FG XR6T. I'm thinking of trying to find a manual, hopefully ex-demo. Anything I should be on the look out for when I test drive these things. I drove one on the weekend and heard some noises that were a little unsettling. The first was a pronounced clicking noise each time I released the clutch (slight feedback through the clutch peddle as well), the dealer assured me it is normal but it just seems like an odd thing to happen in a modern car. The other was a bit of a clunking noise when engaging the clutch in reverse. Should either of these two sounds be happening or is there likely to be something wrong with the car? It's an ex-demo so warranty shouldn't be an issue but Ford isn't noted for its customer service so I'd like opinions from people who know their turbos. I'd like to drive a few more to get a better idea but finding them in manual is proving a bit difficult.Hoping a few people here can enlighten me about the FG.Cheers Link to comment Share on other sites More sharing options...
frogg Member 57 Member For: 14y 6m 21d Gender: Male Location: Bundoora, Melbourne Posted 08/02/11 03:43 AM Share Posted 08/02/11 03:43 AM I have an FG XR50T, and get the same "Clunking" in reverse when engaging/diesngaging clutch.....Also have a noise while in Neutral, and had it looked at at the 1000km inspection and told it was "Normal for this gearbox" though I will be complaining at the 15k service again....Thanks Link to comment Share on other sites More sharing options...
Chopdog New Member 15 Member For: 14y 2m 20d Posted 08/02/11 04:10 AM Share Posted 08/02/11 04:10 AM when I test drove a demo it had that same noise when changing gear Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 8m 15d Gender: Male Location: Earth Posted 08/02/11 04:42 AM Share Posted 08/02/11 04:42 AM When depressing the clutch pedal the clicking noise you are referring to sounds like the reverse lock out solenoid.Try this.With the ignition on depress the clutch and then release it. If you hear the clicking sound, that will be the reverse lockout solenoid. perfectly normal.The slight clunk you are referring to when engaging reverse may be a sign of slight synchro wear.If it worries you, ask them to change the gearbox oil to a synthetic fluid and ensure they use 4.85L of oil and not what is written in the owners handbook as that figure is for the V8 model and not the I6. Link to comment Share on other sites More sharing options...
Alex86 Member 2 Member For: 14y 26d Posted 08/02/11 06:11 AM Author Share Posted 08/02/11 06:11 AM So that clicking is normal everytime you depress and release the clutch peddle? Who designed that I wonder. It wouldn't be too much of an issue if it weren't so loud. I could hear the clicking at 3000-4000rpm with the windows down, admittedly not going freeway speeds but still a bit disappointing. Link to comment Share on other sites More sharing options...
j.d Member 1,222 Member For: 14y 7m 7d Gender: Male Location: Eastern Suburbs, Melbourne Posted 08/02/11 06:23 AM Share Posted 08/02/11 06:23 AM I think the clicking is due to the clutch passing a switch or something? you shouldn't be able to hear it at 3000-4000 rpm though I wouldn't think, I cant in mine Link to comment Share on other sites More sharing options...
plcains Member 49 Member For: 14y 8m 11d Posted 09/02/11 11:48 AM Share Posted 09/02/11 11:48 AM Mine clicks too, but ive noticed it only does it when a gear is under load, like in 1st slowing using engine braking and then depressing the clutch or when the car is off and being held by first, then depressing the clutch. Link to comment Share on other sites More sharing options...
j.d Member 1,222 Member For: 14y 7m 7d Gender: Male Location: Eastern Suburbs, Melbourne Posted 10/02/11 06:18 AM Share Posted 10/02/11 06:18 AM you will be able to hear the clicking sound, while car is on or off. whenever your clutch reaches about half way in or out! Link to comment Share on other sites More sharing options...
