Screaming Noise From Xr6t
len
  • Member For: 22y 2m 10d
I have noticed a rather loud screaming sound that seems to come occassionally from the engine area when accellerating quickly from around 100Kmphr. The sound is like say an alternator with buggered beariings or a fan belt slipping something terrible.
The sound only occurs sometimes (its happened about 6 times in about 4 months) when planting the accerelator at around 100 Kmphr. It sounds terrible.
Has anyone else experienced such a sound.
Any idea what it could be (turbo, auto transmission??).
  • I don't suffer from insanity; I enjoy every minute of it
  • Member For: 22y 2m 20d
Haven't heard it, and have NFI what it might be. Doesn't sound good though. Have you mentioned it to your dealer??
Guest Trevor
  • Guests
Hey, len,
I have had this problem and posted resultant actions in another forum but can't remember where, so here is the answer.
The top corners of your windscreen have plastic clips under the weather strip. The wind gets in there and resonates. Ford paid for windscreens obrien to replace my screen and that fixed the problem.
NOTE: A new windscreen wasn't acctually the answer. The fix would have been simply to lift the old screen and have them smear some urethate arount the edges of the plastic clips. This seals them off enough to get rid of that horrible screech.
Hope this helps,
Trevor
  • Flaccid Member
  • Member For: 21y 9m 19d
Only horrible screaming I get is from the passengers.....
nobody at work will get in the car with me anymore. :(
  • Flower Power
  • Member For: 22y 5m 2d
My company has a policy, I can't have more than one tech with me in the car at any one time...
  • ....Time to lay this fairytale aside......
  • Member For: 22y 2d
  • Location: In the Ferry on the River Styx, not getting out just yet!
Hey, len,
Hope this helps,
Trevor
Len,
Trevor is right, I had the same problem with the 'hawk. The eurathane bead under the screen is too small.
The windscreen needs replacing because there is every chance it will crack while being removed.
If you don't want the screen replaced there is a cheap fix of a plastic moulding that goes in the gap between the roof and the top to the screen, does'nt look too bad.
Personally, I'd get the windscreen replaced.
Al
  • FORD FORD FORD
  • Member For: 21y 11m 23d
Since My grunt factor has increased my car makes an occasional shreek, in 1st gear under full load, it's the belt slipping. Took the head tech for a demo run & he's going to remove the idler pulley & revove a casting tag that's on them. He said that ford told him to perform this on any car that has unusual wear on the belt. It's being done on the 19th, hope it stops as it sounds worse than Ricky Martin!!
Scotty
I winged about my belt shredding rubber every where,oh that's normal,if we put a new one on the same thing would happen.
Lucky rotten jhonny took my gun off me.
  • Gandalf the Grey, Maiar of Manwë and Varda, Team HgAg/Sneaky
  • Member For: 21y 8m 10d
I'm surprised they let YOU in the car! :lol:
