djextreme Member 112 Member For: 15y 9m 2d Gender: Male Location: Melb Posted 19/09/11 08:52 PM Share Posted 19/09/11 08:52 PM DiD u use any thread tape or lock tight ????Cheers buddy Link to comment Share on other sites More sharing options...
Garrettba03 Member 78 Member For: 13y 7m 21d Gender: Male Location: Sydney West Posted 06/10/11 02:25 AM Share Posted 06/10/11 02:25 AM (edited) no need to retune with a F6 cooler, has been tried and tested by alot of people, including myself.The F6 cooler is a bigger version of the standard cooler, and no more efficient when it comes to flow... it may reject a bit more heat, but your not going to notice any difference in powerThe Blow off is probably quieter as you have introduced more bigger pressure drop into the setup.A decent aftermarket cooler will reduce pressure drop and have better flow. hence why you need a re-tune...F6 cooler should actually flow better, its higher and has more bars across, meaning more air passages and less resistance against charge air flow, reducing air speed.Unless theres something internally different or its skinnier Edited 06/10/11 02:28 AM by Garrettba03 Link to comment Share on other sites More sharing options...
Jakeychanxr6turbs New Member 10 Member For: 6y 9m 26d Gender: Male Location: Emu Plains Posted 25/04/18 06:20 AM Share Posted 25/04/18 06:20 AM Anybody out there ? I’m trying to do this today on my 2007 mk II xr6t and am stuck big time , I can’t get the f6 intercooler into place with either standard brackets or the typhoon brackets that came with the cooler , seems the f6 cooler is roughly 1 inch wider and has the scensor thing for the gauge , any suggestions as to what order I should be doing the cooler and brackets as I’m buggered , been trying for 2 hours since removing old cooler and nowhere near success yet , please help ?? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 10d Gender: Male Location: Perth Posted 25/04/18 06:44 AM Share Posted 25/04/18 06:44 AM (edited) You need to use the F6 brackets. It's a straight swap. It will all line up and then you will see you need to to drill one hole I gather you have the bumper and front of the car removed Edited 25/04/18 06:44 AM by arronm Link to comment Share on other sites More sharing options...
Jakeychanxr6turbs New Member 10 Member For: 6y 9m 26d Gender: Male Location: Emu Plains Posted 25/04/18 06:48 AM Share Posted 25/04/18 06:48 AM Thanks heaps Arronm , yes everything off the car so it’s exposed as much as possible , do I attach brackets to car then try install the cooler , or attach brackets to the cooler first ? also , do you know what side I should expect to have to drill a hole ? thanks heaps for getting back to me , at least now I can push forward with the typhoon brackets ?? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 10d Gender: Male Location: Perth Posted 25/04/18 07:32 AM Share Posted 25/04/18 07:32 AM I can't remember. It was more than 10 years ago. Assemble both with brackets put side by side. Then work it out 1 Link to comment Share on other sites More sharing options...
Jakeychanxr6turbs New Member 10 Member For: 6y 9m 26d Gender: Male Location: Emu Plains Posted 25/04/18 08:51 AM Share Posted 25/04/18 08:51 AM Thank you so much for all your help and posting those pics , I’ll have another crack Friday night , cheers mate Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 10d Gender: Male Location: Perth Posted 25/04/18 09:09 AM Share Posted 25/04/18 09:09 AM (edited) Was 10/06, off it came for process west... Edited 25/04/18 09:10 AM by arronm Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,199 Member For: 16y 9m 27d Gender: Male Location: Melbourne Posted 25/04/18 12:24 PM Share Posted 25/04/18 12:24 PM (edited) The F6 cooler goes straight in. Unbolt the old one at the bumper leaving the brackets on, unbolt the brackets if necessary for the space. The F6 cooler slides in with a bit of effort then bolts into the same holes on the bumper. Edit: have a look at my post here: http://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/?do=findComment&comment=1640380 Edited 25/04/18 12:30 PM by k31th Link to comment Share on other sites More sharing options...
Jakeychanxr6turbs New Member 10 Member For: 6y 9m 26d Gender: Male Location: Emu Plains Posted 26/04/18 09:02 PM Share Posted 26/04/18 09:02 PM Thanks very much mate for your advice and link with pics , hopefully I can go at it fresh tonight or tomorrow night and get it in ?? Link to comment Share on other sites More sharing options...
