stapes88 Inactive Members 1 Member For: 14y 27d Posted 04/02/11 01:54 AM Share Posted 04/02/11 01:54 AM Hey guys,Ive just put a BF F6 intercooler on my 05 xr6 turbo. Do I need to get it tuned so the air/fuel mixtures are right or is it ok as is? Also, I took the plumbing pipe off the stock BOV so it vents into the atmosphere. Before I put the F6 cooler on, it used to be quite loud and flutter sometimes. Now the F6 cooler has made the ptshhh alot quieter and almost no flutter at all. Is that normal for a larger cooler? Thanks in advance. Link to comment Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 1m 28d Gender: Male Location: Liverpool NSW Posted 04/02/11 05:09 AM Share Posted 04/02/11 05:09 AM no need to retune with a F6 cooler, has been tried and tested by alot of people, including myself.The F6 cooler is a bigger version of the standard cooler, and no more efficient when it comes to flow... it may reject a bit more heat, but your not going to notice any difference in powerThe Blow off is probably quieter as you have introduced more bigger pressure drop into the setup. A decent aftermarket cooler will reduce pressure drop and have better flow. hence why you need a re-tune... Link to comment Share on other sites More sharing options...
callanmack Member 21 Member For: 15y 2m 18d Posted 04/02/11 07:34 AM Share Posted 04/02/11 07:34 AM summed up well good post Link to comment Share on other sites More sharing options...
djextreme Member 112 Member For: 15y 9m 2d Gender: Male Location: Melb Posted 18/09/11 10:20 PM Share Posted 18/09/11 10:20 PM What type of bolt do I need to plug up the hole in the fpv cooler Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 11d Gender: Male Location: Melbourne Posted 18/09/11 11:20 PM Share Posted 18/09/11 11:20 PM What hole? Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 3m 15d Gender: Male Posted 19/09/11 01:07 AM Share Posted 19/09/11 01:07 AM Don't know what it's called Dillz but there is some sort of sensor there. Link to comment Share on other sites More sharing options...
djextreme Member 112 Member For: 15y 9m 2d Gender: Male Location: Melb Posted 19/09/11 03:23 AM Share Posted 19/09/11 03:23 AM Yeah where the old sensor goes :-) Link to comment Share on other sites More sharing options...
T6EGO Donating Members 91 Member For: 14y 9m 2d Gender: Male Posted 19/09/11 06:45 AM Share Posted 19/09/11 06:45 AM I blocked the hole in my old typhoon cooler with a 301grade bolt don't have the size now but will check when I get home. Link to comment Share on other sites More sharing options...
T6EGO Donating Members 91 Member For: 14y 9m 2d Gender: Male Posted 19/09/11 07:16 AM Share Posted 19/09/11 07:16 AM Damn it I've taken the bolts out and thrown the packaging. well they are champion brand and I measured the diameter of the thread with a digital caliper and it's telling me it's between 12 and 12.6mm with a length of 25mm. Anyway got mine from autobarn. Comes in pack of 4. Hope this helps Link to comment Share on other sites More sharing options...
djextreme Member 112 Member For: 15y 9m 2d Gender: Male Location: Melb Posted 19/09/11 08:52 PM Share Posted 19/09/11 08:52 PM Sweet thanks mate I got an autobahn across the rd,When I get the cooler back from my mate who gave it a quick spray I'll go get a bolt ,N bang it inCan't wait Link to comment Share on other sites More sharing options...
