Project Unopenned Ba
Panda Eyes
  • flame magnet
  • Member For: 16y 9m 7d
under battery intake pipe, there only 2 1/2" most of them,
turbo inlet is 3" so pipes a resticrtion
run it straight out to a 3" pipe filter,
or go a big air box setup, ones I do have a 6" bell mouth, 6" k& n filter, then goes to 4" and tapers down to turbo at 3"
got a linky?
  • Replies 84
Posted Images
  • flame magnet
no kaboom, although everyone at the workshop thought it would go... they put trays under the dyno so they didnt have to clean the floor off so much....
we started off with 98ron. result was 343.5rwkw. remembering that the most I had was 351rwkw with 1/2 e85 and 98 ron.
the boost rises from 17psi mid range up to 19psi at 6000rpm.
then we added e85 to make a 50/50 mix.
the result was 363.6rwkw. boost rises from 16psi mid range to 17psi all the way to 5500rpm where is peaks to 19psi.
I cant upload charts at the moment due to having reached my upload quota for the forum, but will do so when this is sorted.
a couple of thoughts on the .performance: bruce was NOT impressed with the plenum. its a jd custom, similar to process west as best as I can tell. it is HUGE, and although ive got very strong low end performance, bruce reckons the air speed would suck.....
this seems to be the case, because when we removed the under bat cai, allowing the air to enter straight into the turbo, we lost 20rwkw!
theory is that the pod filter gave some regularity to air speed. prol reduced stupid amounts of air cramming into plenum, kinda like 10 fat guys entering a door single file instead of all trying to cram through at once...
fix to this will be to sell the jd plenum and get a nispro or similar. alot smaller in volume but more efficient.
I was expecting more than 15rwkw above previous max power, but there were some other changes made since that run was done. I replaced the 'hi flowed' stock ba cat section going to twin 2 1/4 stock pipes to twin 2.5" cat back system, with twin 2.5" 100cpi bullet cats going to twin 2.5" pipes. this made the smallest section of the exhaust twin 2.5".
the general consensus is that this change has probably hindered flow, so I am thinking of getting the new cats 'hi flowed', but am unsure whether I should.
the other change is that I now have a histalled built btr. this robs power of course.
I also have not done any turbo mods at all. flapper mod and port job would definately increase power. a/r .7 comp cover would improve flow too. valve springs are only oem typhoon ones. crow would no doubt improve things too, as the car was unsettled a bit after 6000rpm runs.
all in all I am happy with the result. it's the highest power original motor ba that has ever been on that dyno, slightly beating bruces own ba he did back in the day.
interestingly, after 15 or so dyno runs, bruce ran off for a torch, to check it actually is the original motor, as we started to get doubtful when it didnt pop. it is.
where to next? prol will get a wrecked bf 2 and do a motor and zf transplant. then with the mods I have, should be staring down the barrel of 450....
Edited by fordriver1
  • Member For: 18y 8m 28d
well at least it's still together.
The flapper mod and wastegate port will not give any power at all, it just allows better control of the boost to stop an unwanted overboost situation.
  • Banned
  • Member For: 15y 7m 6d
+1 ^.
Unfortunately those jd plenums havnt been heavily tested in 350+rwkw cars. So you made 351rwkw with 50/50 with no histall, but now made 363rkw with bigger exhaust system more boost 50/50 still but a converter. Still massive power. Its no 400. Headsex is the closes I know with a ba standard internal motor. Mind you that's on full pump juice.
Maybe try a full e85 tune?
The UBI are good for 350rwkw you would need the nizpro relocation kit when you get the plenum. Your still looking at alot of big bucks infront of you unfortunately.
Just be thankful its still one piece! Kick the crap out of it whilst you get the new motor ready!
  • Member For: 17y 3m 18d
I made 360rwkw + on straight BP98, not even so much as octane booster in it BA MK1 engine, and engine's been fine for 2yrs with this power with regular caining's, only removed it to run in my Atomic motor but as soon as everything sorted with that my stock engine is going back in...
  • HOON
  • Member For: 14y 11m 9d
With the stallie 360 would be around 400rwkw's bet it boogeys along nicely...get it down the 1/4 and see what it can do....my ute made 350rwkw's @ 16psi and it came on strong also had a 3000 stallie for 2 years with no problems
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 24d
yeh scotty ya *beep* come to the fags with us ull blend in nicely :buttrock:
bloody spuin I wasnt there to see it on the rollers it would of been good the dr have anything to say about your madness this time
