Tockley Member 51 Member For: 16y 7m Gender: Male Location: Melbourne Posted 02/02/11 03:02 AM Share Posted 02/02/11 03:02 AM Finally time to spend my hard earned on the turbo - hoping for some advice! 07 Bf2...Looking at 250-260rwkw. I am currently running 205rwkw with k&n and lower snorkel.I am thinking:cat back xforce 2.5" - looks and sound more so than power and on a budget - thoughts?x3 custom tuneDBA 4000s all roundWill I need to go some bigger injectors for this power output? 60lb? What about surge tank and fuel pump?Anything else I should also get done to keep it reliable - someone suggested oil feed line and screen should be done in another thread?Cheers guys. Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/ Share on other sites More sharing options...
Brods Member 433 Member For: 14y 9m 3d Gender: Male Posted 02/02/11 03:55 AM Share Posted 02/02/11 03:55 AM Should get that figure with just a tune mate. Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077574 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 5d Gender: Male Location: @ my laptop Posted 02/02/11 04:19 AM Share Posted 02/02/11 04:19 AM You will need injectors for that power level, fuel pump is normally good for approx 300 rwkw assuming yours is operating correctly, an intercooler will help intake temps lower Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077580 Share on other sites More sharing options...
Weaponxr Donating Members 624 Member For: 14y 4m 21d Gender: Male Location: Melbourne Posted 02/02/11 04:35 AM Share Posted 02/02/11 04:35 AM My car just made 261kw at the wheels just with a tune and a k&n panel filter so I think you should be alright with just getting a flash tune Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077584 Share on other sites More sharing options...
Kv! Donating Members 1,132 Member For: 15y 2m 16d Gender: Male Location: Eastern Suburbs, Melbourne Posted 02/02/11 07:33 AM Share Posted 02/02/11 07:33 AM If your on a budget, I would suggest a hiflow cat, injectors and a tune, for the time being...The cat will give you a deeper note that sounds surprisingly good.Henz made 300rwkw with the above mods in a Manuel on a safe tune Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077640 Share on other sites More sharing options...
tonyv EPC Member Donating Members 1,598 Member For: 16y 4m 29d Gender: Male Posted 02/02/11 07:40 AM Share Posted 02/02/11 07:40 AM do cat, tune,fuel pump, injectors and f6 cooler. That should net you 290-300rwkw Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077641 Share on other sites More sharing options...
Brods Member 433 Member For: 14y 9m 3d Gender: Male Posted 02/02/11 08:06 AM Share Posted 02/02/11 08:06 AM Is it a manual? If it is may need to factor in a clutch. Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077649 Share on other sites More sharing options...
j.d Member 1,222 Member For: 14y 9m 5d Gender: Male Location: Eastern Suburbs, Melbourne Posted 02/02/11 08:11 AM Share Posted 02/02/11 08:11 AM As few others have said, I would be doing cat, injectors and tune! You should see 250 easy!! Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077652 Share on other sites More sharing options...
j.d Member 1,222 Member For: 14y 9m 5d Gender: Male Location: Eastern Suburbs, Melbourne Posted 02/02/11 08:13 AM Share Posted 02/02/11 08:13 AM Also if it is a Manual clutch should be fine!! All depends on your driving style though! Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077655 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 12d Gender: Male Location: Vic Posted 02/02/11 10:55 AM Share Posted 02/02/11 10:55 AM If your only going to tune it once and you want good bang for buck, you should look at doing injectors/ hi flow cat/ x cal 3/ tune/ inline filter. Will come in under 3k and you will probably gain around 80rwkw. Link to comment https://www.fordxr6turbo.com/forum/topic/73015-mods-time-finally/#findComment-1077732 Share on other sites More sharing options...
