nxr06 Donating Members 117 Member For: 20y 11m 29d Posted 31/03/11 05:40 AM Share Posted 31/03/11 05:40 AM Where there any issues with high engine oil temps at all, or is it more just pre-caution to install the cooler?I also have virtually identical gear list as you for my BF F6, just got to get the atomic bottom end so I can crank it..... Im please to hear spool up time is good...... Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1093352 Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 7m 8d Posted 31/03/11 11:58 AM Author Share Posted 31/03/11 11:58 AM Where there any issues with high engine oil temps at all, or is it more just pre-caution to install the cooler?I also have virtually identical gear list as you for my BF F6, just got to get the atomic bottom end so I can crank it..... Im please to hear spool up time is good......Was done mostly as a precaution, however engine temps did increase with the new turbo set up before the cooler was installed. Have no problems with engine temps now, even after giving it a boot full over extended periods.. Ben Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1093491 Share on other sites More sharing options...
ALF05T Member 453 Member For: 18y 3m 11d Gender: Male Location: Sydney Posted 18/04/11 10:20 PM Share Posted 18/04/11 10:20 PM Fantastic set up mate,If I didn't have the hand brake holding me back I would have had my car back on the road 6 months ago!If you don't mind me asking what sort of outlay did your set up cost? Not being nosy just weighing up my optionsCheers lf Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1098002 Share on other sites More sharing options...
Marsh Member 9 Member For: 14y 10m 18d Posted 22/04/11 08:04 AM Share Posted 22/04/11 08:04 AM Awsome setup. What size is the rear housing on that turbo....(can't believe no one has asked?) Out of curiosity how often do you have the bio fuel in the tank? Well done! should do a slippery 10 Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1098969 Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 7m 8d Posted 22/04/11 09:12 AM Author Share Posted 22/04/11 09:12 AM Fantastic set up mate,If I didn't have the hand brake holding me back I would have had my car back on the road 6 months ago!If you don't mind me asking what sort of outlay did your set up cost? Not being nosy just weighing up my optionsCheers lfCheers mate, I wouldn't dare post what I spent on here as I have a feeling my "better half" is spying on me I mean taking interest.. So, it was cheap and everything was done by Ford under warranty.. Honest.. Ben Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1098993 Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 7m 8d Posted 22/04/11 09:26 AM Author Share Posted 22/04/11 09:26 AM Awsome setup. What size is the rear housing on that turbo....(can't believe no one has asked?) Out of curiosity how often do you have the bio fuel in the tank? Well done! should do a slippery 10 Thanks mate, I will have to double check with Kyle from 6BOOST what the rear housing was again and get back to you.I have only had a couple of runs on the street with E85, the standard ZF doesn't like the power one bit.. Hopefully that will be fixed in the next couple of months.Ben Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1099000 Share on other sites More sharing options...
f6mark Member 2,908 Member For: 14y 2m 11d Gender: Male Posted 22/04/11 09:47 AM Share Posted 22/04/11 09:47 AM Thanks mate, I will have to double check with Kyle from 6BOOST what the rear housing was again and get back to you.I have only had a couple of runs on the street with E85, the standard ZF doesn't like the power one bit.. Hopefully that will be fixed in the next couple of months.Benhey Ben. howz the car going mate.??? what's ya next step going to be mate.?? Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1099005 Share on other sites More sharing options...
BAjoe Banned 43 Member For: 14y 28d Gender: Male Posted 22/04/11 12:53 PM Share Posted 22/04/11 12:53 PM when will this monster ever hit the track? first ever 9 sec FG is still on the cards... Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1099048 Share on other sites More sharing options...
AtomiCg6 Donating Members 197 Member For: 14y 12d Posted 11/05/11 05:32 PM Share Posted 11/05/11 05:32 PM Hey Ben...Nice motor, gets me very excited, As I get my 698 long motor bak from Atomic this wk Just wondering did u get stage4 cams and heads work in it? And how did the injecters work with your setup? is it worth going biggerim running the same turbo and identical fuel system !! I got told to use bigger injecters thou, for the e85 ? And wat gearbox u goin ?cheers johnny.. Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1105159 Share on other sites More sharing options...
BAR61R New Member 15 Member For: 13y 2m 14d Gender: Male Location: sydney parramatta Posted 15/02/12 04:38 AM Share Posted 15/02/12 04:38 AM That's mad so keen to get a e85 tune good stuff man worth it Link to comment https://www.fordxr6turbo.com/forum/topic/72992-fg-f6-610-rwkw/page/6/#findComment-1196496 Share on other sites More sharing options...
