howesy Member 30 Member For: 18y 8m 19d Posted 24/01/11 08:09 AM Share Posted 24/01/11 08:09 AM Pulled the intake tube off the turbo on my Fg today (2000km on the clock) and there was cleanish engine oil in it. There was enough that to wipe it with your finger was like wiping a dipstick. The oil was coming straight out of the turbine.Is it normal for oil to go through like this and if so how much is too much Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/ Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 9d Gender: Male Location: Vic Posted 24/01/11 09:28 AM Share Posted 24/01/11 09:28 AM A bit is normal, basically a small pool in the front cover is normal. Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1075224 Share on other sites More sharing options...
howesy Member 30 Member For: 18y 8m 19d Posted 24/01/11 09:58 AM Author Share Posted 24/01/11 09:58 AM (edited) Thanks Edited 25/01/11 05:51 AM by RHR No need to quote above post. USE FAST REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1075236 Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 17y 19d Gender: Male Location: Greenvale, Victoria Posted 24/01/11 10:29 AM Share Posted 24/01/11 10:29 AM If it worries you, and it can, get yourself an oil catch can from super cheap or repco for $60. I have a mate with an FG with the same issue and he put on in and it fixed his. Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1075241 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 11m 9d Gender: Male Location: Earth Posted 25/01/11 04:00 AM Share Posted 25/01/11 04:00 AM Expect there to be that much and potentially more until your engine is properly run in.The service schedule calls for the intake pipework to be cleaned every 15k service as well.I just removed all mine and cleaned it with some degreraser. Dry before refitting and look forward to the next service. If it is just a small amount it sould be fine, but keep an eye on it as there has been a couple of cases of cartridge seal failure which leads to a lot more oil being dispoced intot he pipework. Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1075391 Share on other sites More sharing options...
SecaBoy Donating Members 203 Member For: 16y 3m 26d Posted 03/02/11 02:25 AM Share Posted 03/02/11 02:25 AM mine is leaking oil into the piping AFTER the turbo... ie the hot side of the intercooler piping...so much so that its actually dripping out of the joins in the pipes... my intake manifold is covered with oil now... :(ford's response: that's completely normal. nothing wrong.so I'm guessing, even if you empty the engine oil into the intake system, ford will say its normal... :lol: Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1077905 Share on other sites More sharing options...
Damo_XR6T Member 10 Member For: 14y 5m 29d Gender: Male Location: SA Posted 15/02/11 12:09 PM Share Posted 15/02/11 12:09 PM what was oil level like? I no over filling oil can cost oil to pump throught turbo, makes big mess can go through cooler ect. but none on my turbo cars have had that problem, but I do see alot a turbo with oil through turbo housing at work, best just keep a eye on it. Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1081402 Share on other sites More sharing options...
xwkid Member 7 Member For: 14y 2m 16d Gender: Male Location: Newcastle Posted 13/03/11 06:45 AM Share Posted 13/03/11 06:45 AM oil after the turbo sounds like turbo oil seals from oil seal failure , only other way is if the intake (suction side ) has a restriction and the turbo draws the oil past the seal . Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1088590 Share on other sites More sharing options...
Marcone Member 34 Member For: 14y 3m 5d Gender: Male Location: Morley, Perth Posted 18/03/11 09:06 AM Share Posted 18/03/11 09:06 AM Link to comment https://www.fordxr6turbo.com/forum/topic/72869-fg-turbo-oil-in-intake/#findComment-1089977 Share on other sites More sharing options...
