  • Member For: 18y 9m 2d
Just got a brand new FG Turbo and if the vehicle breaks traction it results in severe multiple banging coming from the rear axle like it has severe axle hop and cant get power down. Its really bad and sounds like the ar&e end of the car is going to come out.
Is this normal it sounds shocking. Happens with or without traction control.
  • Member For: 21y 10m 5d
Yes it'll be tramp. Mine does it if I deliberately try to give full throttle in 1st to provoke wheel spin. Mine stops once in second. Not good for the driveline and I usual back straight off if it happens, horid sound.
Benny
  • It's not a MKI!
  • Member For: 16y 11m 23d
Stiffer springs and Bilsteins will cure it. That's what I did to mine to stop it. If it has been doing it for a while as bad as you describe I'd be checking the rear diff bush for failure. It doesn't take much for them to collapse in the FG.
  • Sandtrap Motorsport
  • Member For: 16y 6m 17d
manual FG sedans <3 axle tramp.
people say coilovers help, I didnt notice a difference.
one method is proven... more power = less tramp. ;)
  • Carnage on the Garage Floor
  • Member For: 15y 1m
Yeah, it's not nice the first time you hear it. I'm going to do the nolathane diff bush insert (not the total replacement version) which fits inside the voids of the OEM rubber bush. This stiffens it up without the nasty noise transfer associated with the full nolathane replacement. It will prevent the rubber bush from failing and stop the diff from flogging around in the cradle which is what the 'bang' is. Pedders also recommend replacing the control blade bushes with nolathane but again, you get noise transfer (I am an old fart after all). People that have done either of these, or both, have reported a significant reduction or totally cured it. Shocks and springs also help but I don't want to fiddle with them at this stage.
It's also true that more power helps. Post tune, nowhere near as bad. Mine is an auto and I have changed the way I launch to prevent it. Basically, I feed first then mash the throttle early in second. Fights the traction control, kicks to the left with wheelspin, but little or no tramp. By this time I'm into third and away clean. Probably not the best for a quick 60 foot but I'd rather that than tear the bush out, smash the hat off the diff, or poke the tailshaft though the floor! Cheers, Bomber.
Edited by bomber
