  • Member For: 14y 6m 5d
  On 25/01/2011 at 4:05 PM, Arkayne said:
I always wondered what the benefit of an intercooler is on a supercharger. Anyone care to enlighten? I'm aware how it works for the i6 turbo, but how does it work for the gt 335 if you fit an aftermarket one? Or, in this case, if Fpv put a stock one on the gt-ho?
Intercoolers on superchargers work exactly the same as they do on Turbos. The air from a supercharger is still compressed and heats up and thus needs a heat exchanger to lower the intake temps. The needand benifits of a larger intercooler will be obvious once the boost pressure is increased over standard.
  • Replies 43
  • Member For: 15y 4m 2d
basically the hotter air cant have as much fuel with it as its not as dense. So you cool it making it dense allowing more fuel and more power effectively.
  • Member For: 17y 5m 25d
Awwwwwwwwwwww
  Quote
Edit – 28/01/2011:
After posing the question to FPV, Rod Barrett, General Manager, Ford Performance vehicles, had this to say about the photographs:
“The vehicle shown undertaking testing in Sweden is an engineering mule vehicle used as part of the Miami engineering development program. During this program the vehicle was based in Europe, and other parts of the world. Specifically, it has been used to calibrate the vehicle’s electronic traction control, anti-lock-brakes and dynamic stability control systems.
This prototype vehicle has been fitted with heat exchangers designed to allow engineers to control engine intake air temperatures, independent of prevailing ambient conditions. In other words, the vehicle can be tested on very low friction surfaces currently present during the Swedish winter, while at the same time the engineers can simulate the engine performance as if the test was being conducted in 40 deg C temperatures in the Northern Territory.
This system has been installed for development purposes only, and is in no way related to the development of a model designated GT-H or GT HO. The FPV GS and GT have class-leading power and torque outputs from the Supercharged 5.0 litre V8 engine. To achieve this, the GS and GT do not require an engine intercooler system.”
  • Seriously Flukey Member
  • Member For: 21y 1m 29d
Its a development mule from Ford Oz. Why would it not be registered in Vic?
  • 2 weeks later...
  • 2 weeks later...
