JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 11d Gender: Male Location: Adelaide Posted 23/01/11 07:07 AM Share Posted 23/01/11 07:07 AM ok guys iam gunna run a BOMB IN THE BOOT style swirl pot surge tank well I already got it and I would love to know of anyone that has used fuel hose within the cabin of any car and has has a susessful hose that dont stink/breath?cause itl be mounted in the boot I really dont want the smell of fuel clogging the carso the hole set up uses speed flow fittings thread one side and press on the other side so all the sonnections to the 044 and the tank are threaded and all the hose ends are just press on then down to the std fuel pump location.need some advice on the best hose to use to rapidly reduce or eliminate the smell of fuel and should I use any type of thread tape on the threaded ends of the tank fittings? Link to comment https://www.fordxr6turbo.com/forum/topic/72844-fuel-hose-for-speed-flow-fittings/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 11d Gender: Male Location: Adelaide Posted 24/01/11 07:09 AM Author Share Posted 24/01/11 07:09 AM well so far the info I found out is use the blue/black fittings for speed flow and use teflon hose cause everything else will stink hopes this helps out anyone else Link to comment https://www.fordxr6turbo.com/forum/topic/72844-fuel-hose-for-speed-flow-fittings/#findComment-1075168 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 10m 23d Gender: Male Location: Sydney NSW Posted 24/01/11 07:31 AM Share Posted 24/01/11 07:31 AM Yeah the teflon braided hose is "said" to be the stuff to use... I used it on my twin 044/surgy in the boot but theres still some light smells on 98... cant smell anything with E85, so you know what my answer is LOL Link to comment https://www.fordxr6turbo.com/forum/topic/72844-fuel-hose-for-speed-flow-fittings/#findComment-1075179 Share on other sites More sharing options...
tekaani Donating Members 163 Member For: 15y 9m 24d Posted 24/01/11 07:35 AM Share Posted 24/01/11 07:35 AM I had a track gtr with 2 044's and a 040 lift pump in the boot. had braided line but it wasnt teflon, the smell was unbearable for a period of longer than 30 minutes. the only way you will not have the fuel smell is to use teflon and teflon speedflow fittings. not cheap either. if you can, try stay away from any surge tanks that you have to push a hose onto then worm drive clamp it. wont work. Link to comment https://www.fordxr6turbo.com/forum/topic/72844-fuel-hose-for-speed-flow-fittings/#findComment-1075180 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 12d Gender: Male Posted 26/01/11 12:42 AM Share Posted 26/01/11 12:42 AM Goodluck. I ended up using metal bundy tube, teflon tube wasn't around much a few years back but may be the way to go. Bet bet is to keep it out of the boot for a daily driver. The fuel permeates thru normal or even viton lined fuel hoses. THe viton lined fuel hoses were meant to stop permeation but never did totally. Link to comment https://www.fordxr6turbo.com/forum/topic/72844-fuel-hose-for-speed-flow-fittings/#findComment-1075581 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 11d Gender: Male Location: Adelaide Posted 26/01/11 01:41 AM Author Share Posted 26/01/11 01:41 AM cheers for the answers guys exactly what my conclusion has come to iam gunna use this set up just for the drags at heathcote on march 27 then make it removeable in and out for when I need it looks like the p/w style surge tanks are worth the r&d coin after all Link to comment https://www.fordxr6turbo.com/forum/topic/72844-fuel-hose-for-speed-flow-fittings/#findComment-1075595 Share on other sites More sharing options...
