plonky The Bionic Man - half man-half titanium Member 1,766 Member For: 22y 1m 1d Location: Dodge Scat Pack Posted 14/11/03 10:11 AM Author Share Posted 14/11/03 10:11 AM AMoffat said: Dear Ponch...Is it true that slant radar doesn't work in moderate rain?Or is this urban myth no. 398? Slant radar was used last century!!In fact we still have one in the garage at work.Heavy rain only makes a difference if the beam that is sent is reflected or bounced off the road surface thus giving an imprecise reading. However, it is the operators responsibility to make sure that the Patrol speed correlates with the checked speedometer.If the radar is stationary then heavy rain slows down the beam by making a 'curtain'. It is pretty dumb and a waste of time to use the instrument when it is raining heavily or you can;t get a patrol speed to correlate. Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64876 Share on other sites More sharing options...
curious Member 504 Member For: 21y 6m 8d Location: sun, beach and plenty of T T's Posted 14/11/03 10:21 AM Share Posted 14/11/03 10:21 AM plonky said: AMoffat said: Dear Ponch...Is it true that slant radar doesn't work in moderate rain?Or is this urban myth no. 398?Slant radar was used last century!!In fact we still have one in the garage at work.Heavy rain only makes a difference if the beam that is sent is reflected or bounced off the road surface thus giving an imprecise reading. However, it is the operators responsibility to make sure that the Patrol speed correlates with the checked speedometer.If the radar is stationary then heavy rain slows down the beam by making a 'curtain'. It is pretty dumb and a waste of time to use the instrument when it is raining heavily or you can;t get a patrol speed to correlate. that's how far QLD is behind. Qld cameras are slant radar teamed up to the GATSO camera system. Stationary slant detection however has been booted for the more up to date and super effective LIDAR.(laser) Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64878 Share on other sites More sharing options...
AMoffat Member 744 Member For: 22y 5m 3d Posted 14/11/03 10:50 AM Share Posted 14/11/03 10:50 AM OK, I know nothing about radar (which is becoming obvious real quick), but, none-the-less...In NSW is it true that you can only be 'caught' or photographed from the rear? And, why are stationary radar (the poles and the cameras) at 45 degrees to the traffic while the hand held units are straight front on? Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64882 Share on other sites More sharing options...
curious Member 504 Member For: 21y 6m 8d Location: sun, beach and plenty of T T's Posted 14/11/03 12:47 PM Share Posted 14/11/03 12:47 PM Plonk can answer that one from a NSW perspective as I am unaware what they use. In QLD it can be both front on and rear on but "flash policy" states that in the hours of darkness you must take from the rear. Front on is a more effective way as it calculates the speed differently as it does in away mode. In away mode you get more "illegals" This is where two vehicles enter the beam at the same time, the CPU will map a graph of vehicle one (if I can remember some 450 times in a splt second) and if a second vehicle enters as the CPU is doing this it tells itself two or more vehicles are present and ignores them all reagrdless of what speed it is doing. The reason for the angle could be a number of things depending on what system they use. Once reason is deffinately flash. If you take a photo of yourself in the mirror it is stuffed cause all you see is light. This is the same if you took a photo of a plate due to its reflectorised characterisitcs. The lights must hit it at an angle so it lights it up and bounces off instead of coming back on the camera. Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64902 Share on other sites More sharing options...
plonky The Bionic Man - half man-half titanium Member 1,766 Member For: 22y 1m 1d Location: Dodge Scat Pack Posted 14/11/03 07:34 PM Author Share Posted 14/11/03 07:34 PM TrueWhat Curious said is correct Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64918 Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 21y 11m 19d Gender: Male Location: NOONAMAH, go figure..... Posted 15/11/03 01:26 AM Share Posted 15/11/03 01:26 AM Quote Once reason is deffinately flash. If you take a photo of yourself in the mirror it is stuffed cause all you see is light. This is the same if you took a photo of a plate due to its reflectorised characterisitcs.Hey! good Idea Curious, so what if you mount a "slave flash" that photographers use near your plates? As the camera flash fires the slave fires also and stars out the shot. Wouldn't go encouraging people to do things like that Curious, It's probably illegal! :lol: Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64974 Share on other sites More sharing options...
Velvet Glove Team Blueprint Member 532 Member For: 22y 1m Posted 15/11/03 02:10 AM Share Posted 15/11/03 02:10 AM curious said: Plonk can answer that one from a NSW perspective as I am unaware what they use. In QLD it can be both front on and rear on but "flash policy" states that in the hours of darkness you must take from the rear. Front on is a more effective way as it calculates the speed differently as it does in away mode. In away mode you get more "illegals" This is where two vehicles enter the beam at the same time, the CPU will map a graph of vehicle one (if I can remember some 450 times in a splt second) and if a second vehicle enters as the CPU is doing this it tells itself two or more vehicles are present and ignores them all reagrdless of what speed it is doing. The reason for the angle could be a number of things depending on what system they use. Once reason is deffinately flash. If you take a photo of yourself in the mirror it is stuffed cause all you see is light. This is the same if you took a photo of a plate due to its reflectorised characterisitcs. The lights must hit it at an angle so it lights it up and bounces off instead of coming back on the camera. Look out ! Someone will raise that bullsh*t 'prism' paint argument again Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64980 Share on other sites More sharing options...
Velvet Glove Team Blueprint Member 532 Member For: 22y 1m Posted 15/11/03 02:12 AM Share Posted 15/11/03 02:12 AM Dear Ponch, Do you wear the attractive tight blue jodphurs ? Do you find than these 'trousers' present a more manly front than the baggy blues. Would you prefer lycra shorts for summer duties.luvFashion Police Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-64981 Share on other sites More sharing options...
aniken I don't suffer from insanity; I enjoy every minute of it Donating Members 4,316 Member For: 22y 4m 21d Gender: Male Location: Sydney, south west Posted 15/11/03 04:21 AM Share Posted 15/11/03 04:21 AM Old Chinese proverb: curious said: ...in the hours of darkness you must take from the rear.Each to their own I suppose :hiwelcome: Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-65002 Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 21y 11m 19d Gender: Male Location: NOONAMAH, go figure..... Posted 15/11/03 05:28 AM Share Posted 15/11/03 05:28 AM Quote aniken Posted on Nov 15 2003, 02:21 PM Old Chinese proverb:QUOTE (curious @ Nov 14 2003, 11:47 PM) ...in the hours of darkness you must take from the rear. Each to their own I suppose :hiwelcome: Classic! Link to comment https://www.fordxr6turbo.com/forum/topic/7284-ask-ponch/page/14/#findComment-65016 Share on other sites More sharing options...
