tuono Member 312 Member For: 14y 7m 23d Posted 25/01/11 07:59 AM Share Posted 25/01/11 07:59 AM Thanks for that. They certainly do there job well!! Big drop. Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075438 Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 15y 5m 20d Gender: Male Posted 25/01/11 09:01 AM Share Posted 25/01/11 09:01 AM but that's not for the above cooler, the above cooler is probably not as good, but something that's bolt in no cutting is never going to be as good as a larger modify car to fit unit Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075445 Share on other sites More sharing options...
Kv! Donating Members 1,132 Member For: 15y 4m 20d Gender: Male Location: Eastern Suburbs, Melbourne Posted 25/01/11 09:04 AM Share Posted 25/01/11 09:04 AM (edited) Not bad,Bit too skinny for my liking, maybe cos of the size of the grill? and the PWR logo looks pretty avg Edited 25/01/11 09:05 AM by kvbaby Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075448 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 11d Gender: Male Location: Brisbane Posted 25/01/11 10:33 AM Share Posted 25/01/11 10:33 AM Oh Johnny what have you done Make sure you park it out on the street next time you're at bowls or the old boys will not be impressed. Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075482 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 9d Gender: Male Location: @ my laptop Posted 25/01/11 10:38 AM Share Posted 25/01/11 10:38 AM unless he goes to "Boosted Bowlers" Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075483 Share on other sites More sharing options...
Johnny G Team Grandpa Qualified Donating Members 809 Member For: 20y 4m 23d Gender: Male Location: Brisbane North. Posted 26/01/11 12:18 AM Author Share Posted 26/01/11 12:18 AM LOL - Mmmmmm - new rear window sticker; "Boosted Bowlers", and maybe a little Super Roo carrying a turbo and a Bowls Bag.... there's a thought!I knew leaving the spray on advertising was a gamble and would draw a little flack . I sat there looking at it, then covered it up, then said "stuff it".... and it sure draws the head turns, no doubt. Actually, I'm really happy with the front on look -understated with bit of hey wait a minute - same reason the 3.5"tail pipe is just an angle cut off with no chrome tip, painted black.AndrewD = Plazmaman pipe set via Karl at Hiroperformance. And yeah - clamps.... any suggestions anyone? I think these will go once the front comes off again... not overly fussed with three spot welds on the clamp anchor.... Anyone who wants the data sets on this cooler PM me and I'll email them to you (Tuono) - I'm stuffed if I can remember where I found them... might even be on here somewhere. Includes graphs - but is a pretty big file (2.3mb). Excerpt from that file summary (note - standard car): Top of second gear the Stock intercooler outlet temp was 24 degrees above ambient compared to PWR intercoolerat 8Deg.• Stock intercooler peak pressure drop in first gear of 1.03 psi. The PWR unit peakingat 0.41psi.• Stock intercooler Total temp drop at this stage was 55Deg . PWR unit at 73Deg.• Engine water temp still constant at a slightly lower 206 Deg.3rd gear: Top of third gear the Stock intercooler outlet temp was 31 degrees above the ambient compared to the PWR7Deg.• Stock intercooler peak pressure drop in third gear of over 0.61 psi compared to thePWR of 0.02psi.• Stock intercooler total temp drop at this stage was 66 Deg, compared to the PWR88Deg.No intercooler wars here guys - this one suited what I wanted (big as possible without an air saw to do a hackathon), looked the goods, used the standard mounts so I can swap it back easy if needs be to support the mortgage payments, and provided a little bit more than needed for the occassional squirt on a hot Brisbane day... and the psi this is running it needs a breath of fresh air. Happy as Larry with the result at 30 deg yesterday - fantastic... and now as I can get more than one run out of the dam thing :laughrolling: !PS Tab - I'm finished now. I think. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075578 Share on other sites More sharing options...
juggernaut Member 71 Member For: 16y 27d Posted 26/01/11 01:16 AM Share Posted 26/01/11 01:16 AM (edited) Out of interest, is this the "stepped" PWR intercooler. Edited 26/01/11 01:16 AM by juggernaut Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075589 Share on other sites More sharing options...
juggernaut Member 71 Member For: 16y 27d Posted 26/01/11 01:45 AM Share Posted 26/01/11 01:45 AM Link to data on PWR cooler Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075597 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 9d Gender: Male Location: @ my laptop Posted 26/01/11 01:53 AM Share Posted 26/01/11 01:53 AM That original data may not be accurate anymore as PWR made changes to improve their cooler in december Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075599 Share on other sites More sharing options...
juggernaut Member 71 Member For: 16y 27d Posted 26/01/11 01:55 AM Share Posted 26/01/11 01:55 AM (edited) That original data may not be accurate anymore as PWR made changes to improve their cooler in decemberYes I see that the end tank design has now changed...for what appears to be much better. Perhaps other changes made too that are not so obvious. Results could only be better then?What sort of max (safe) power could someone expect from one of these new coolers. Edited 26/01/11 01:57 AM by juggernaut Link to comment https://www.fordxr6turbo.com/forum/topic/72838-bling-it-up/page/2/#findComment-1075600 Share on other sites More sharing options...
