  • Member For: 15y 9m 18d
Changed rotors and pads on the front over on the weekend and found the piston dust boot to be disintegrating.
Rang ford parts:
4x seals = 50.20
4x dustboots = 69.60
Does anyone know of any other suppliers for these ?
If not I suppose I'll front at the ford counter and bend over again.
Edited by Skidude
https://www.fordxr6turbo.com/forum/topic/72719-piston-seals-dust-boots-fg/
Don't think warranty will cover it.
Not when they see the slotted rotors & A1RM pads in there.
Might have something to do with hitting 180kms at the bottom of Wakefield and jumping on the brakes to slow to 70klms in the space of 150 metres on the last two track days !
  On 18/01/2011 at 3:50 AM, EGOXRT said:
They are the same kits as used in the AUII, ring Repco or Burson
Thanks mate.
Will try them in the morning.
Seems as this is a real weak point in the stock caliper.
Last few track days I've had smouldering brakes (ferodo DS Performance), but next to no fade.
When I said disintegrating, it just flaked away when touching it.
Benny, it might be worthwhile you checking yours out as seem to recall you running Ferodo DS & DBA slotted.
I doubt it but I'll ask Matt if anyone makes a higher temp dust boot seal.
Edited by Skidude
  • Member For: 21y 10m 20d
Yeah it's got me thinking. I'm due for new pads so I'll have to inspect mine. Yeah I doubt Matt would have an upgrade part but maybe replacement seals.
Benny
Re: Pads
Got the A1RM's from Matt for $119. All seems good after 200k's.
I found the Ferodo's to be good pads but dusty as all buggery.
Temp spec charts I've found for the DS only seem to go to 600c.
Decided to go A1RM's as feedback has been 99% good and they're rated to 780c.
A1RM's are suppossed to be equivalent/better than the Ferodo DS2500 (a step up from the DS performance).
Next track day will tell.
Edited by RHR
No need to quote above post. USE FAST REPLY
  • Member For: 15y 6m 9d
I use to overhaul automotive brakes in Brisbane a few years ago and we use to get truck loads of these calipers off taxis with all the same problem. Boots and seals crisp like they had been in a fire.
I know we used a company called MCX Trading (also in Brisbane) for our caliper kits and out of the ordinary fluid seal or boots. They are wholesalers so you will have to source the kits through an automotive shop or try a decent brake reconditioning firm. Even if you have to have them sent down express post they will surely be much cheaper then genuine and excellent quality.
Edited by ikon
